Tires and Back spacing help - JeepForum.com
post #1 of 7 Old 09-17-2013, 10:19 AM Thread Starter
BOVWJ
Sorry if this has been covered all ready.
I Have a set of M/T classic lock blacks 16x8 with 4" back spacing. I am trying to figure out what tire size will allow minimal to no trimming will work best. Due to the Backspacing I am not sure how much this will affect it. I was hoping for some 265/70 but I am a little worried about them rubbing to much. I will be running Rough Country 2" BB on a 2001 WJ (Daily drive)
any pics. on what and how much you did trim would be great
Thanks for your input.
BOVWJ is offline
post #2 of 7 Old 09-17-2013, 10:52 AM
brouwmat
Not sure about the backspacing, but I'm thinking you should go to a 4" lift in order to get those under there. I have a 4" lift and get occasional rubbing (lightly) on the bottom side of the front bumper. I haven't trimmed yet and don't really plan to.
brouwmat is offline
post #3 of 7 Old 09-17-2013, 03:13 PM
swkenobi
2003 WJ
You should be able to get a 3 inch lift with no trimming for those tires. The 2" BB will require some trimming of the front bumper. I think there is a thread going around with a chart that shows the various tire sizes and lifts. [/QUOTE]
2003 Grand Cherokee Limited - Mostly Stock
swkenobi is offline
post #4 of 7 Old 09-17-2013, 03:46 PM
bcvetter
I run a 265/75/16 with no trimming. However when I wheel I rubs when flexed.
I have a 3" IRO with Bilsteins. I would go 3" IRO or OME. It's only a couple hundred more than a budget boost with good shocks.
Just my 2 cents
bcvetter is offline
post #5 of 7 Old 09-17-2013, 03:58 PM Thread Starter
BOVWJ
I under stand the chart, But right now I am running 245/70 at stock height with zero trimming and rubbing. I would assume I could increase that a little bit with the 2" BB (right)? How much will the back spacing affect it? that's what I am more worried about.
BOVWJ is offline
post #6 of 7 Old 09-17-2013, 11:07 PM
3Dog
My best guess is that the 4" BS on your 16x8 wheels will cause some additional issues (stock is 16x7 with ~ 6" of BS). On one hand, a wider tire (say 265) will clear your suspension components with no problem. On the other hand, the reduced BS will cause more clearance issues on your front bumper - the BS and wider wheel will amplify the problem, especially in reverse at full lock. Plan on trimming with a 2" BB, even if only increasing tire size to 245/75/16. In short, the BS and width of your choice of wheels will probably cause you to need to trim the bumper cover if you plan on bigger-than-stock tires.
3Dog
2015 WK2 Overland Hemi ORA II
2000 WJ Limited 4.7L (sold)
3Dog is offline
post #7 of 7 Old 09-17-2013, 11:13 PM
turrillas
I run my WJ with 265/70R17 with a 4" lift kit and they rub a little when I do an U turn and turning the steering wheel all the way, but is minor rubbing. Mine are BFG's all terrain.
turrillas is offline
