tired of poor performance please help - JeepForum.com
post #1 of 10 Old 02-16-2014, 06:41 PM Thread Starter
Jrboarder27
For a while now I have been trying to chase down the cause of poor performance and getting quite fed up with it, I will try to explain every thing the best that I can . To start I cant tell if this is transmission or engine because it seems to have to drop to far down in gear and rev way high to get any extra power and from a stop it seems to be in to high a gear and revs more then it should before switching gears (does not feel like trans slipping). However if giving it WOT it hesitates quite a bit and that seems engine related to me. Now here is the kicker some time I take a drive and it has all its power back and runs great, but thatís rare, and I cant find any thing that coincides with the jeep running great and running bad.
Now here are a few other things that might be related. I use to have a rough idle that could be described as a shake every few seconds but I decide to clean the MAP sensor and the Air intake temp sensor and the shake went away but not the poor performance and its still a little rough when cold . I have a hissing sound from behind the dash that I canít pin point, but Iím sure its not the brake booster because I already replaced that and nothing changed. every once in a while ( maybe once a month I have trouble starting the engine until I give it some gas .
I have replaced the TPS with a Mopar and replaced the fuel filter with a microgard from Oriellys. I have cleaned the throttle body and the IAC and again no change. I have of coarse kept up on regular maintenance although sparkplugs time is getting close but Iíve been having issues since before this set.
Any help or ideas would be greatly appreciated
Jrboarder27 is offline
post #2 of 10 Old 02-16-2014, 07:43 PM
sprocket1200
what engine codes are present?
unless i missed it, the engine size would be helpful as well.
sprocket1200 is offline
post #3 of 10 Old 02-16-2014, 08:04 PM Thread Starter
Jrboarder27
I knew I was going to forget that, 2000 4.7, and most annoying part is NO codes, I wish I had at least one that could lead me some were.
Sent from my Galaxy S4 using JeepForum
post #4 of 10 Old 02-16-2014, 08:21 PM
cr8zynelly
Would start with plugs and go from there. Check your coils when doin the plugs. Kill 2 birds with one stone. Then you can at least check those off the list.
cr8zynelly is offline
post #5 of 10 Old 02-16-2014, 08:23 PM
cr8zynelly
Could also try an injector cleaner or sea foam. I would do plugs first.
post #6 of 10 Old 02-16-2014, 08:26 PM
cr8zynelly
Also fuel filter if it hasn't been changed.
Good luck!!
post #7 of 10 Old 03-26-2014, 11:00 PM Thread Starter
Jrboarder27
Ok so time for an update. It turns out that I can get good V8 power like I should, but only if I restart the engine after its already warm, for instance, 15 minute drive, eat some lunch (also seems the engine needs to be off for 10 or so minutes) get back in turn it on and the thing flies down the road, I'm lost, the only thing I've done sense last post was replace the air intake temp senser. and it got me the power more often, but it still goes back and forth.
post #8 of 10 Old 06-09-2014, 07:24 AM Thread Starter
Jrboarder27
Time for another update, I just recently replaced my crank shaft position senser do to random shut downs of the engine at 70 mph. I am happy to say that It dies seem that I have fixed that problem, and gained a bit of my performance back.
I am now currently looking in to the transmission speed sensors. I started to get some hard shifts and strange gear choices on the trannys part
Quick question, I know some of you have used a multimeter to check the ohms on these speed sensors, so I did the same and got .614m on one and .584m on another and I read on another thread that a new one reads at .54xxm. So if any of you have heard of this and can chime in that would be great.
post #9 of 10 Old 06-09-2014, 08:22 AM
99SK04GTX
Go online to Advance Auto and use coupon code TRT30 for 30% off and a speed sensor is $21 (order online, P/U at store). Both are the same part number so just buy one and first put it in the rear (output) to begin. If no change move it to the front (input).
99SK04GTX is offline
post #10 of 10 Old 06-09-2014, 11:48 AM Thread Starter
Jrboarder27
I'm buying mopar
