tire size help??? - JeepForum.com
post #1 of 4 Old 03-20-2012, 01:20 AM Thread Starter
wjrunner99
tire size help???
Will a 285/75/16 fit on a stock 99 wj? I have 245/75/16 on there now. The bigger tires are general grabbers at2. I'm not sure if they will rub on the rear strut or how they will b when turning in the front. I only have two now so if I need to buy some narrower ones for the front I can.
wjrunner99 is offline
post #2 of 4 Old 03-20-2012, 01:36 AM
rocky_lange
rocky_lange is offline
post #3 of 4 Old 03-20-2012, 07:55 AM
ChrisHager
Administrator
ChrisHager's Avatar
If you want to completely chop your bumpers and fenders, maybe. 285/75R16 is about a 33" tire. You are lucky you aren't rubbing with the 245/75R16 (30.5" tire) on a stock WJ.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #4 of 4 Old 03-20-2012, 01:34 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
They'll fit in a stock 99 WJ, but not on a stock WJ.
Even with 4-5" lift that size will probably need moderate trimming.
~Richard
billzcat1 is offline
