Time for new bearings? - JeepForum.com
post #1 of 9 Old 11-17-2013, 07:32 PM Thread Starter
nstevic01
Im getting alot of play in the crank shaft, I'm assuming that the thrust bearing is shot. Thoughts?
99 WJ with a 4.0l and Selec-Trac; 01 WJ with a 4.0l and 2wd
nstevic01 is offline
post #2 of 9 Old 11-17-2013, 07:36 PM
99_wj_QD
leave it be, I know that may sound like a bad idea but if there are no abnormal noises from that engine I wouldn't think twice about that play you are seeing...simply proves that your crankshaft is getting good lubrication and the bearings are allowing freedom of movement to that crankshaft.
technically speaking too much endplay on a crankshaft is a bad thing, but realistically I would rather have too much endplay than too little.
99_wj_QD is offline
post #3 of 9 Old 11-18-2013, 08:13 AM Thread Starter
nstevic01
There is a couple of sounds coming from the motor at the moment. One sounds like some sort of pulley bearing failure that is intermittent, this lead me to discovering the crank movement. The other is almost like a light knocking noise. I used the stethoscope on pretty much everything and was unable to pinpoint the origins. I just want to do whatever preventative measures that are necessary to avoid killing the motor all together.
I'm debating a full rebuild at the moment since she has 178k on the clock, but aside from the crank movement and the noises listed above, it runs pretty smooth. So If I can get more use out of it by replacing something and not doing a rebuild, that would be preferred.
post #4 of 9 Old 11-18-2013, 08:50 AM
StrokedWJ
StrokedWJ's Avatar
That does seem like excessive play in the crank. You could pull the oil pan and the thrust bearing for a visual inspection. How is your oil pressure?
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #5 of 9 Old 11-18-2013, 08:51 AM Thread Starter
nstevic01
Between just below and right at the center of the gauge.
post #6 of 9 Old 11-18-2013, 09:04 AM
Jeeples
Jeeples's Avatar
Looks to me like it's more of a worn harmonic balancer vs. bad main bearings. IMO, with that much movement of the crank you would have some pretty serious engine noise. If you look closely at your video, you can see the outer ring of the balancer moving independent of the hub that's actually pressed onto the crank snout. I bet with a pry bar or large screwdriver you can probably replicate that movement with the engine off.
I'd replace the balancer and see if the movement continues.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #7 of 9 Old 11-18-2013, 09:19 AM Thread Starter
nstevic01
I see what your saying, that's pretty good news, Ill check for play with the pry bar and replace the balancer if necessary. I'll report back with any updates.
post #8 of 9 Old 11-18-2013, 09:45 AM Thread Starter
nstevic01
Other things to do while there? I heard to do the timing cover gasket and related seals, which the kit says I have to do the oil pan gasket at the same time? May also tackle the rear main seal if the pan gasket is required.
post #9 of 9 Old 11-18-2013, 09:58 AM
Jeeples
Jeeples's Avatar
Yeah, if you're going to replace the timing cover gasket you need to drop the pan. In your video you can see two bolts along the u-shaped part of the oil pan. Those go straight into the bottom of the timing cover.
It might not be a bad idea to do the oil pan gasket and RMS since you're going to be working in the same general area, not to mention they're common leaks so chances are it's time to do them anyway. It'd be a weekend's worth of work, but the parts are pretty cheap.
Jeeples is offline
