tick tick tick..... no zinc? - JeepForum.com
post #1 of 8 Old 01-03-2011, 07:59 PM Thread Starter
meopilite
When i bought my Jeep (4.0L) there was no ticking. After having it a month i changed the oil and used QuakerState 10-30. Right after the oil change a lifter started ticking. I added some STP oil treatment and the ticking stopped went away. I heard that some oils dont have enough Zinc in them and that will cause ticking (and STP treatment does have Zinc).
So whats the best oil to use? What brand has the Zinc I need?
meopilite is offline
post #2 of 8 Old 01-03-2011, 08:04 PM
compcrasher86
Diesel Truck oil. Mobil TDT and Shell Rotella oil are some of those. Mobil 1 High mileage also has added zinc, mine loves it. This might be a bigger problem than Oil though because you shouldnt be noticing a huge difference. Somebody may have added something to shut it up so they could sell it quick. My sisters i6 runs on bottom of the food chain penzoil and my WJ used to as well until I owned it. Zinc is better for the engine but its not there to quiet down tick.
Matt
compcrasher86 is offline
post #3 of 8 Old 01-03-2011, 08:21 PM
TJSWJ
I had a loud lifter tick in my newly rebuilt 4.0 it was really bad, to the point I was ready to replace the cam and lifters. I switched to mobile 1 high mileage and the tick is about 95% better. Hardly noticeable, I would switch your oil.
TJSWJ is offline
post #4 of 8 Old 01-03-2011, 11:39 PM
compcrasher86
maybe quaker state just isnt one of those i6 oils. I've always run Mobil 1 high mileage for my changes and its great
Matt
post #5 of 8 Old 01-04-2011, 12:25 AM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Oil treatments are garbage (for the most part). If your oil isn't good enough, get better oil. Adding to it won't fix anything. Mobil1 HM is great oil. You may want to do an engine flush (Auto-RX, Amsoil, LubroMoly are good) to help clean the oil passages and provide better flow to the lifters. And as compcrasher said, the zinc is there to prevent wear, not reduce ticking. Higher viscosity oils (such as M1HM 10w-30) will help with that.
~Richard
billzcat1 is offline
post #6 of 8 Old 01-04-2011, 12:44 AM
compcrasher86
As far as additives... I threw a 1/3 can of seafoam in when I used it and I left it in for a week or two before my oil change. Oil came out black as coal and new oil is still golden clean
Matt
post #7 of 8 Old 01-04-2011, 06:29 AM
billzcat1
2003 WJ
I consider that a flush, not an additive. It promises nothing but cleaner engines. Most of the products claiming to improve the oil do just the opposite.
~Richard
post #8 of 8 Old 01-04-2011, 07:04 AM
compcrasher86
Right right, I dont believe in additives I used it just to clean things out shortly before the oil change
Matt
Buy it or Not: 99 Laredo 4.7L 4x4 w/ Engine Tick mtsumedi WJ Grand Cherokee Forum 30 12-19-2010 07:06 PM
TICK TICK Went My Jeep..... myjeeplovesmud WJ Grand Cherokee Forum 36 09-26-2010 10:29 PM
99 WJ tick Go4Lo WJ Grand Cherokee Forum 1 08-03-2010 08:30 PM
2004 grand cherokee straight six tick Envygreen WJ Grand Cherokee Forum 5 07-06-2010 11:12 AM
2001 4.0, tick/knock mostly when cold camosilver WJ Grand Cherokee Forum 1 06-23-2010 05:10 PM
