for those of you with speedoDRD! - JeepForum.com
post #1 of 11 Old 09-23-2013, 03:31 AM Thread Starter
Relax_Jimmy24
anyone on here have the speedoDRD installed on the Jeep WJ? I have 32 inch tires and I want to correct my speedo.
does this thing work and does it actually change the way the Jeep shifts?
I was looking into buying the jet product that corrects the speedo but if this one works, I'll rather go with this one. less expensive
Relax_Jimmy24 is offline
post #2 of 11 Old 09-23-2013, 07:55 AM
TJSWJ
Works beautifully, worth every penny.
It doesn't adjust shift points directly. But it will fool the computer into thinking the jeep is on stock tires again. In turn the computer will shift as it was designed.
TJSWJ is offline
post #3 of 11 Old 09-23-2013, 08:03 AM
bradywgn71
bradywgn71's Avatar
I agree. After putting the 33s on mine, the shift points were way off. I installed the SpeedoDRD and it brought the shift points back to where they were before. I found my speed to be off by about 9.8% compared to the GPS.
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline
post #4 of 11 Old 09-23-2013, 08:50 AM
wvracer821
Ive got one. its the best way to correct for tire size. i plan on using it to corrrect the signal from a NP231 Tcase when i do my axle swap so i can keep my speedo
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #5 of 11 Old 09-23-2013, 09:54 AM
Merc1973
I believe Theksmith did a write up in his build thread.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #6 of 11 Old 09-23-2013, 10:35 AM
jpat30
I am also looking into this and was on their website. Question; which 1 do I need for the WJ; is it the universal kit? it maybe my work computer, but I was having difficulty finding the answer there on the site. Thanks.
-Carpe Diem Phil 1:20
jpat30 is offline
post #7 of 11 Old 09-23-2013, 07:14 PM
bradywgn71
bradywgn71's Avatar
U1 Universal kit
post #8 of 11 Old 09-24-2013, 02:23 AM Thread Starter
Relax_Jimmy24
does it matter which version I get? I see they have version v3m now and it was v3x before.
It should work right?
also when I am done entering the percentage I am off by is that all I have to do? I don't have to mess with any of the other features right?
post #9 of 11 Old 09-24-2013, 07:49 AM
TJSWJ
Yeah, once you enter the correction percentage your done. You can mess with the other features, but I never have. Its geared more towared the bikes anyway.
TJSWJ is offline
post #10 of 11 Old 09-24-2013, 08:49 AM
jdrogers
I have one too. Works great!
2002 WJ Limited, Stone White, 4.7L H.O., Quadra Drive
OME Springs, MX6 Shocks, BFG 265/70R17 All-Terrain, Level 8 Tracker Wheels
Scottsdale, AZ
jdrogers is offline
post #11 of 11 Old 09-26-2013, 08:45 PM
LarryDallas
So I'm just running 245/70/17, so about 30.5", so is it worth it to get it corrected? I think the 1.5" over stock 29" puts speed about 5.5% off.
2001 WJ 4.7L Quadra-drive, UC springs w/ 2" BB, Bilstein 5100s, double cardan front axle swap, Moog Trail Boss SS, 245/70/17 General Grabber AT2 tires,
1.5" Spidertrax spacers, Rola rack, Uniden CB w/ 4' Firestik, JCR Stage 3 rock sliders, JKS HD Adj. track bar, IRO 3" rear sway end links, Akebono swap.
LarryDallas is offline
