Are those 242HDs? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Are those 242HDs?
Regear now with Gear Packages from JeepHut.comSmittybilt M1 Fender Flares + FREE Machete$40 off over $400 + FREE SHIPPING!!!
Unread 05-06-2013, 02:31 PM   #1
04RockyMountain
Are those 242HDs?
Hi everyone I know i should be able to tell if these are HD or not but still not sure. I have two sets of picd
Set 1
Sorry about the crappy message using my phone please let me know if those are HDs i know some 242Js came as HDs thanks in advance
Set 2
Jeepin' Since I Know Myself!!!
04RockyMountain is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 02:44 PM   #2
USFORCES
First one is a HD, Count the splines it should be 32.
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 02:55 PM   #3
04RockyMountain
Thank you USFORCES even though it says J but its got the aluminium cover so its most likely an HD right? I would count them but its an hour from here i will ask him to count for me
Unread 05-06-2013, 03:00 PM   #4
ratmonkey
R.I.P.
ratmonkey's Avatar
it's HD. they pretty much randomly put the HD or WJ tag on them.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 03:06 PM   #5
04RockyMountain
Ok cool so as long as the cover is aluminium we are good to roll right? Thanks again everyone... also if u can check my other post can you confirm that noise is my TC going bye bye? Thanks
Guy texted me nd said 23 splines is that even possible?
Unread 05-06-2013, 03:25 PM   #6
04RockyMountain
As per the guy it has 23 splines??? Is that even possible?
Unread 05-06-2013, 03:39 PM   #7
jeep0086
23 spline is the input shaft and 32 on the output shaft for it to be an hd. the non hd's are 23 spline input with a 27 spline output.
SOLD--00 WJ limited 4.7l HO paxton SUPERCHARGED 18 lbs, 9.0 Ross coated pistons, crane 224 cams, f&b 72 tb, 2008 intake manifold, scat rods, arp studs , ati balancer, sct tuned, 47 lb injectors, port and polished race heads
06 WK Overland HEMI
jeep0086 is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 04:09 PM   #8
04RockyMountain
Thanks brother i contacted him he is closing the place now maybe tomorrow i can find out thanks again
