things to look for - JeepForum.com
post #1 of 7 Old 11-02-2011, 11:20 AM Thread Starter
MoparMan1990
1992 XJ Cherokee
things to look for
okay ive got an oil leak and it looks to be the rear main seal.. but ive read alot of things that most of the time it looks to be the rear main but its not.. the valve cover gasket looks like its leaking from the rear but i cant tell because i cant see back there.. what else should i look for.. (4.0) i think the drain plug is leaking but not sure.. anything else i should look for.. any help would be great.. thanks ahead
MoparMan1990 is offline
post #2 of 7 Old 11-02-2011, 04:56 PM
Tezzating
Rear main seal, oil pan gasket, could be the valve cover gasket but it wont look like a leaking rear main, that`ll just make a mess around the head area.
But if you need to do the pan gasket, then you may as well do the rear main seal cos its only 4 extra bolts once the pans out. If you do the rear main seal, you need to do the pan gasket anyway cos the pan comes out to do it.
Tezzating is offline
post #3 of 7 Old 11-02-2011, 08:49 PM Thread Starter
MoparMan1990
1992 XJ Cherokee
im thinking its the valve cover gasket and the o ring for the oil filter because im getting out on the bottom of the oil filter.. ill post a pic.. the oil is coming from above the intake to the right.. the only thing i could see that being is the valve cover gasket?
post #4 of 7 Old 11-02-2011, 10:14 PM
ry1820
Put a little bit of oil UV dye in your crankcase and get a small UV light. (both of these can be purchased on ebay for like 5 bucks). Degrease your engine and drive around for about 20 minutes.
Shine the UV light on the engine, when it's dark, and you will see where the leak is coming from.
Good luck!
05 GC Limited - 4.7 Quadra-Trac II ~127,000 miles
12 GC Limited - 5.7 V8 Quadra-Drive II ~11,000 miles
99 GC Limited - 4.7 V8 - Quadra Drive (sold; 110,000 miles)
02 GC Laredo - I6 - Selec Trac (sold; 123,000 miles)
04 GC Limited - 4.7 V8 - Quadra Drive (sold; 132,000 miles)
07 GC Limited - 4.7 V8 - Quadra-Trac II (sold; 78,000 miles)
(OlllllllO)
ry1820 is offline
post #5 of 7 Old 11-02-2011, 10:17 PM
ry1820
Also..could very well be the oil pressure sensor. This is very easy to replace (and cheap too) and often leak presenting the same issues you have.
(OlllllllO)
ry1820 is offline
post #6 of 7 Old 11-02-2011, 10:20 PM
88Jeff94
You sound like you have a similar leaking problem to my jeep. I figured out mine was from the valve cover gasket, but it driped down the back of the oilpan and even on the starter. At first i thought it was a oil pan gasket but then i traced the leak up to the valve cover. My engine is the 4.2 but I think they are pretty simmilar. Not sure if that helps you but the uv dye sounds like a good idea.
88Jeff94 is offline
post #7 of 7 Old 11-02-2011, 10:29 PM Thread Starter
MoparMan1990
1992 XJ Cherokee
same thing 88jeff.. mine leaking from the back of the valve cover from wat i can tell... and i dont see what else would come from up there as far as oil.. and the oil pump was replaced right before i bought it i dont have the receipt but the gasket is new i can tell just by looking at it
Things to look for? yellowtj99 WJ Grand Cherokee Forum 1 06-09-2011 01:07 PM
Need help figuring out what this things are on my WJ? wyattrhicks WJ Grand Cherokee Forum 11 04-03-2011 02:59 PM
Things To Do ExoticFish WJ Grand Cherokee Forum 20 03-09-2011 08:38 AM
Strange things Aceman21 WJ Grand Cherokee Forum 5 12-29-2010 12:46 PM
Help with relays and a few other things Kheeney5 WJ Grand Cherokee Forum 0 04-21-2010 06:26 PM
