Are these Speedo vs GPS results normal? - JeepForum.com
post #1 of 3 Old 05-18-2011, 08:12 PM Thread Starter
=KZ=
Wj Are these Speedo vs GPS results normal?
So I borrowed a buddies handheld GPS to test my speedo and got some results I wasn't expecting.
At low speeds like 15 MPH actual speed was a touch lower by 1.5 mph
At medium speeds 40 MPH Actual speed was bang on.
At higher speeds 60 MPH actual speed was touch higher 1.5 MPH
I was wondering if this is correct or if I made a mistake?
I have tires which are oversized 30.5"
Also does the speedometer and odometer receive the same data or are they different somehow?
=KZ= is offline
post #2 of 3 Old 05-19-2011, 01:32 AM
MeanGreenZJ
That's not too far off. You can have the pinion factor adjusted to bring it a little closer.
MeanGreenZJ is offline
post #3 of 3 Old 05-19-2011, 01:35 AM
XJcory
The speedometer in my XJ consistently reads about 3-4mph higher than what my gps says and what those police speed trap read outs say, and that's with stock size tires. My WJ seems to be about spot on though, as far as I can tell.
XJcory is offline
Is this normal? jeep1987 WJ Grand Cherokee Forum 12 01-30-2011 06:55 AM
tcm flash results in relation to towing? meb12b WJ Grand Cherokee Forum 20 10-05-2010 08:21 AM
Compression Test Results edub70 WJ Grand Cherokee Forum 1 09-25-2010 04:29 AM
4.0 very sluggish...normal? lakailimited06 WJ Grand Cherokee Forum 11 03-22-2010 12:26 PM
Is this normal? Bob K WJ Grand Cherokee Forum 6 11-26-2003 12:04 PM
