Teves calipers to Akebono calipers - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Teves calipers to Akebono calipers
Poison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!Free shipping on slip yoke eliminator kits New lower Price
Unread 01-30-2012, 08:58 AM   #31
4Tom
Originally Posted by brianj42 View Post
Back up again.
Ok. Replaced the Teves with a nice new set of Akebono's. Complete brand new set apart from the attachment bolts which the supplier omitted to include. But hey, the old attachment bolts worked so on went the Akebono's. Then after a few weeks I get a clunking from the front left which I put down to a worn Tie rod which I have ordered. But
Out last night to test and the clunking gets worse, and when I brake it clunks on touching the pedal.
Off with the wheel, and to my amazement the top caliper attachment bolt has gone and the brake caliper is hanging on by the bottom bolt only and that one is loose.
Why would this be ? Is the attachment bolts from the Teves not the same as the Akebono's or did I just not tighten them enough and they have worked loose ?
Thanks
Brian
When I replaced my Callipers with Akebono full replacement Kit new bolts where included along with lock tight glue already on them. I can't remember the torque but it was high. It’s very common if these aren't torqued to spec and the locking glue isn't used that they will come lose.
It was just as well I got new bolts as I stripped the head off my old bolts removing them.
WJ 2001 3.1TD
http://www.jeepforum.com/forum/f22/2001-wj-3-1td-1252959/
Tom
4Tom is offline   Reply With Quote
Unread 01-30-2012, 09:56 AM   #32
billzcat1
Chicken in a Turkey Suit
2003 WJ
Brake Caliper Slide Pins (caliper-to-carrier): 53 ft-lbs
Brake Caliper Anchor Bolts (carrier-to-spindle): 76 ft-lbs
The FSM doesn't specifically require Loctite, but its a good idea.
billzcat1 is offline   Reply With Quote
Unread 01-30-2012, 11:58 AM   #33
BigDaveWJ
BigDaveWJ's Avatar
The Akebono caliper and mounting bracket can be purchased from Napa.
BigDaveWJ is offline   Reply With Quote
Unread 01-30-2012, 12:01 PM   #34
BigDaveWJ
BigDaveWJ's Avatar
Sorry to dig this one up, is it ok to replace one side Teves with a Akebono ? I replaced 2 original Teves with 2 new Teves only 2-3 months ago and now one of them is siezing again.
I would still upgrade to Akebono. The wheel vibration and rotor warping happens because of the week design of the Teves caliper. The Akebono will make your truck feel like a different vehicle. Probably the best upgrade I did on my truck.
Unread 01-30-2012, 12:02 PM   #35
BigDaveWJ
BigDaveWJ's Avatar
Wj Replace the Teves calipers
Unread 02-21-2012, 07:55 PM   #36
Cowboyup94
I know this is going back far but I have looked on napa and cannot locate the parts. any chance you have a link to the parts?
Also I really would like to order throught napa to get a discount! thanks for your help!
Cowboyup94 is offline   Reply With Quote
Unread 02-21-2012, 11:24 PM   #37
OTownDaddy
2007 XK Commander
How do you know if you have a warped rotor? Also, if you're going to replace the Teves with Akebonos, should you also pop on new rotors while you're there?
2007 XK Limited 4x4 | QD-II | 18" wheels (gotta dump these for some 17s) | The rest is stock
OTownDaddy is offline   Reply With Quote
Unread 02-22-2012, 05:06 AM   #38
Augie56
You can reuse your rotors when going from Teves to Akebonos, if they arent warped or scored-up too bad. I re-used mine when swapping in my Akebonos a montha go, and my WJ breaks smooth and straight ever since. Remember to CLEAN the anchor bolts and holes and torque to the German torque spec "Gudenteite" if you don't have a torque wrench.
Augie56 is offline   Reply With Quote
Unread 02-22-2012, 06:06 AM   #39
BigDaveWJ
BigDaveWJ's Avatar
Napa for calipers
I was looking and there is an array of different mounting brackets and calipers. You could just go to the counter and ask. When I bought mine they had a complete kit for each side.
Unread 02-22-2012, 06:33 AM   #40
OTownDaddy
2007 XK Commander
That is friggin hilarious!
Will the torque spec come with the new caliper installation instructions, or is there some tribal knowledge I need to dig up?
Unread 02-22-2012, 11:46 AM   #41
Kolak
Vendor
Kolak's Avatar
Which is tighter Gudenteite or Neisenteite?
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
kolak@aol.com or kolak@kolakperformance.com
Kolak is offline   Reply With Quote
Unread 02-23-2012, 06:13 PM   #42
BigDaveWJ
BigDaveWJ's Avatar
Wj How you know
The front end will vibrate like crazy when braking.
I would change the rotors too. The are not very expensive. I actually used cross drilled slotted rotor, and they were $90.
Unread 02-23-2012, 06:52 PM   #43
Poseidon
I just ordered a set of Rotors/pads and calipers from Kolak for my wife's WJ, great price on the whole kit. I think I am going to paint the calipers Racing Red for the wife, what do you think?
Poseidon is offline   Reply With Quote
Unread 02-23-2012, 07:27 PM   #44
4Doors
You can use your fingers to get it Neisenteite, but you've gotta have a wrench to get it Gudenteite. Otherwise it's just not safe.
4Doors is offline   Reply With Quote
Unread 02-24-2012, 10:54 AM   #45
Ideford Jeep
I replaced my calipers with an Akebonos kit a while back after the dreaded ceasing on - the heat generated melted the rubber seals!
Anyway, my pads will soon need replacing - are they the same as fitted to the post May 2002 WJ?
Ideford Jeep is offline   Reply With Quote
