Testing electric fan with mech fan - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Testing electric fan with mech fan
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!FLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-14-2015, 05:28 PM   #1
mustang67ford
I have a standard electric fan but added a clutch and mechanical fan. How do I test to electric fan without removing mechanical fan? Can't see the elec fan run but it might be because the mechanical fan is keeping it cool.
mustang67ford is offline   Reply With Quote Quick reply to this message
Unread 04-14-2015, 05:51 PM   #2
madds2444
Turn you A/C on full that will make it run, you could also pull the plug on the coolant temp sensor it will run at 100% but it will also make your check engine light come on
madds2444 is offline   Reply With Quote Quick reply to this message
Unread 04-14-2015, 07:09 PM   #3
mustang67ford
Thanks, I'll it a try.
Unread 04-14-2015, 07:51 PM   #4
losttech
losttech's Avatar
Its pretty easy to see if its turning or not like the poster said just turn the A/C on and it should kick on you can hear it to has a different sound then the clutch fan.
losttech is offline   Reply With Quote Quick reply to this message
