Temp control problem after heater core change. - JeepForum.com
post #1 of 1 Old 03-29-2010, 05:23 PM Thread Starter
krakaman24
So, I just knocked out a heater core replacement in my 2000 WJ Limited with the dual zone controls. While I had everything apart I replaced my blend doors and recirc door that so commonly fail. I thought I did a good job and had no issues until I turned on the heat....
The heat comes on when I select the "cold" setting and the A/C comes on when I select the "hot" setting. I obviously hooked something up backwards or installed a door in the open position when it should have been closed or something to that effect. Other than the temps being backwards everything else works fine.
Can anybody tell me exactly what it is that I need to change?
I want to be able to know exactly what I'm trying to do before tearing out the dash again! It's kind of hard to do a trial and error when the dash is out. You can't exactly turn on the controls and test things.
Any input would be greatly appreciated. Thank you.
krakaman24 is offline
blend door , heater core , recirc door , temperature
Heater flap control problem klockdoc ZJ Grand Cherokee Forum 14 05-27-2010 06:28 PM
Heater Core Problem jtsjeep99 ZJ Grand Cherokee Forum 1 11-08-2008 09:51 PM
Heater control problem, help please! Parsonsbri ZJ Grand Cherokee Forum 14 01-11-2008 08:41 PM
zj temp control problem rm1515 ZJ Grand Cherokee Forum 2 08-01-2005 07:50 AM
Heater/air control will not change vents overseer ZJ Grand Cherokee Forum 8 08-29-2004 07:29 PM
