Tech help please - JeepForum.com
post #1 of 4 Old 03-08-2013, 09:06 AM Thread Starter
varanus69
Tech help please
Can anyone point me in the right direction on this repair please. Every time I press the brakes on my 01 larado my the jeep kicks out of overdrive. Mechanics at Chrysler have no idea and say there is nothing connecting the two so that shouldn't be happening.
varanus69 is offline
post #2 of 4 Old 03-08-2013, 10:41 AM
bradywgn71
bradywgn71's Avatar
Actually, the brake switch is connected to the transmission module. When you press the brake, it tells the transmission to unlock the torque converter and if you slow enough, it'll shift out of overdrive too. It's normal.
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline
post #3 of 4 Old 03-08-2013, 12:12 PM Thread Starter
varanus69
On mine it kicks out of overdrive the second you touch the brakes even tap then regardless of speed even at 10mph. The of off light comes on in the dash and you have to hit the button again when you start driving. Previous owner put a zip tie strap around the button on the shifter to stop it from kicking out.
post #4 of 4 Old 03-08-2013, 12:19 PM
ZJPunk98
tranny module may have an issue. check on the connections on it. I know the "stealership" mechanic stated no connection issue, but double check.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
