TCase fluid change? - Page 2 - JeepForum.com
post #16 of 21 Old 11-02-2011, 02:14 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Originally Posted by AngryScientist View Post
well, just for the record, my 2000 select trac t-case is capable of using just about any atf, this from the factory manual. my truck was made before atf+4 came out, and the owners manual tells me to use dex-3 atf or atf+3 - in other words, pretty much any ATF. when atf+4 came out, Jeep just specified it in all select trac cases. the cases are the same, so whatever you put in them will be fine.
it's easy enough to find atf+4 though, so thats what i used.
This. Even the manuals used to say you could use Dex3 for the tranny. Once ATF4 came out then they wanted everything to use atf4. Of course, more money for them.
The point being is yes they call for atf4 but you wont do any damage by not using atf4. Some guys have run the fines on motor oil here even and been fine when we have taken them apart. Use any good atf product and your good.
I Have WJ Stuff for Sale
WiCkeDuDe is online now
post #17 of 21 Old 11-02-2011, 02:15 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Originally Posted by wsar10 View Post
I did not state there was.
It is probably needed in the 242 due to the types of metals that are used.
Look you would obviously love to argue with somebody, but i'm just not up for it today, put whatever you want in your truck, scrap you TC, it makes no diff. to me !
I personally will use what is supposed to be used for the reason that the factory uses it, the proper fluid with the proper add pack.
If your not up to it then quit talking. I could care less what you think. There just is no reason ATF4 must be used.
post #18 of 21 Old 11-02-2011, 02:20 PM
Thomahawk
Deleted
Buildthread
Thomahawk is offline
post #19 of 21 Old 11-02-2011, 02:43 PM
mrese
mrese's Avatar
just about any atf, ...... the owners manual tells me to use dex-3 atf or atf+3 - .... pretty much any ATF. ......
"JUST ANY ATF" is not ATF3 or dex 3
Mark
Amsoil Dealer
'99 WJ Limited 4.7 K&N Filter CB 3" IRO
302, 000 miles
mrese is offline
post #20 of 21 Old 11-02-2011, 02:58 PM
ironmatt85
2003 WJ
Read this TSB from chrysler. This is why you use ATF+4... http://wjjeeps.com/tsb/tsb_wj_2101407.pdf
Prices aren't significantly different, especially since its a long service interval for this stuff. If you really want you can make a wine tasting event out of it a check the real difference between the two flavors...
ironmatt85 is offline
post #21 of 21 Old 11-02-2011, 03:24 PM
wsar10
2003 WJ
Oh now come on....what the hell does chrysler know about there own vehicles !!!
C'mon guys lets all use fluids that the factory says not to just so we can all replace our TC's prematurely !!!!!! due to metal and gear break down from fluids that loose there viscosity and friction modifiers 30% faster !!!
just becuase we can......and oh yeah, becuase chrysler makes more money by us buying the correct fluid that is based from a shell base stock.........
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
Fluid change questions alexsious WJ Grand Cherokee Forum 1 05-19-2011 10:57 PM
metal found in Tcase fluid apex02jeepwj WJ Grand Cherokee Forum 15 05-08-2011 03:51 PM
what happens if you use the wrong Tcase fluid? Sandspider WJ Grand Cherokee Forum 6 05-02-2011 11:14 PM
Grey tcase fluid? zeekracing WJ Grand Cherokee Forum 10 02-27-2011 10:20 PM
Transmission Fluid Change 98ZJBlack WJ Grand Cherokee Forum 36 11-27-2010 10:14 AM
