Tail light issues - JeepForum.com
post #1 of 13 Old 12-13-2013, 03:54 PM Thread Starter
MarkBlair
Tail light issues
My driver side tail light is out. The signal works and so does the reverse light. The light comes on when I press the brake but it doesn't come on by itself. Tried replacing the bulb and it didn't work. How do I fix this issue
MarkBlair is offline
post #2 of 13 Old 12-13-2013, 04:13 PM
LI_DSM
Its the contacts on the socket not making contact with the headlight housing. I would either get a new socket or try and pry the little metal tabs up on the one you have. It is very common. It was constantly happening to me I finally got tired of it and ended up splicing into the factory wiring harness and soldering connections to the metal tabs directly. Has never been an issue since.
LI_DSM is online now
post #3 of 13 Old 12-13-2013, 04:39 PM Thread Starter
MarkBlair
Replaced all the bulbs everything is working fine now. Hopefully no more issues.
post #4 of 13 Old 12-13-2013, 09:56 PM
stonefarg-NM
An alternative solution for me was to replace the sockets themselves. Did all six plus new bulbs for around $45. Used 'gen-u-wine' Mopar sockets & no problems in over a year.
via mobile
stonefarg-NM is offline
post #5 of 13 Old 12-14-2013, 06:30 PM
mdavis83
Replace the sockets. I fought this for a while a couple years ago. You didn't fix the problem by changing the bulbs. You just move the socket enough that it's making contact now. In a few days it will move again and not work. Sockets are cheap and very easy to replace. Save yourself the headache and just replace them
mdavis83 is offline
post #6 of 13 Old 12-14-2013, 09:30 PM
sprocket1200
just use dielectric grease in the sockets. cheap and easy.
sprocket1200 is offline
post #7 of 13 Old 12-22-2013, 08:57 AM
logisticalstyle
I'm dealing with this problem again. I'm sure my sockets need to be replaced. I've already replaced the housing and the bulbs. This and the infamous quacking noise from the door locks is driving me crazy.
logisticalstyle is offline
post #8 of 13 Old 12-22-2013, 10:37 AM
00jeepthing
had same problem. went to junkyard $10 for used one ones for both tail lights. just replaced the bad one and have spares on hand. have had no issues since.
00jeepthing is offline
post #9 of 13 Old 12-22-2013, 11:30 AM
braddf
It take 30 seconds and a little pocket knife to fix it. Bend those tabs out and youll be fine. I did mine about 6 months ago.
Build thread: http://bit.ly/1puFzZm
Stock rims for sale: http://bit.ly/1kMw7k5
braddf is offline
post #10 of 13 Old 12-22-2013, 04:28 PM
KayCeeJeep
I've fiddled with tabs, used die electric grease too it works for a while. One side I just replaced though, cheap enough to do. Sounds like you just need a new socket for yours though as they suggested.
KayCeeJeep is offline
post #11 of 13 Old 12-22-2013, 05:03 PM
rdkendrick
2003 WJ
Never worked for me. I just bought a new tail light.
Sent from my iPad using my fingers
rdkendrick is offline
post #12 of 13 Old 12-23-2013, 09:12 AM
KayCeeJeep
Just checked mine its out again after only a few days. Time for some parts!
post #13 of 13 Old 12-23-2013, 09:27 AM
vmo23
You can buy a new taillight complete with new bulbs and sockets for $40 on Amazon. Instead of spending $30 trying to track down the problem with single parts, I find it's easier just to buy the entire thing for $10 more.
The circuit boards in these taillights go bad quite often, so there's only so much bending of tabs and what not before it just stops responding.
As for the infamous quacking noise, search for door lock actuator on this forum. Hope this helps!
vmo23 is offline
