Tail light - JeepForum.com
post #1 of 4 Old 07-29-2007, 03:52 PM Thread Starter
Phishhead856
Tail light
Quick question for you guys.... Just bought my '00 Grand Cherokee limited yesterday and my right brake light is less bright than the left and when the lights are turned on, the right brake light does not work... replaced the bulb, no luck with that... I'm wondering if it could possibly be the socket (the bracket that the bulb plugs into), or if you folks have any other questions. Thank you in advance.
Phishhead856 is offline
post #2 of 4 Old 07-29-2007, 03:57 PM
merlinTec
merlinTec's Avatar
swap it from the other side
merlinTec is offline
post #3 of 4 Old 07-29-2007, 09:54 PM
frogbit1
Try cleaning up the contact surface for the bulb housing. It can get corrosion on it giving you a weak electrical path.
frogbit1 is offline
post #4 of 4 Old 07-29-2007, 11:16 PM
doug.112
i have the same problem look at the metal ring on the inside of the tail light it may be broken and not making contact with the contacts
doug.112 is offline
Brake light works; tail light doesn't manofmany ZJ Grand Cherokee Forum 9 08-20-2012 11:50 PM
tail light not working - brake light does work gd929 ZJ Grand Cherokee Forum 2 06-17-2010 01:29 AM
Replacement Tail Light...not ACTUAL light though Tigggger ZJ Grand Cherokee Forum 3 04-08-2009 09:15 PM
Tail Light and Instrument light problem t_guenther ZJ Grand Cherokee Forum 0 09-18-2008 08:27 AM
Tail light and Brake Light Question Thedjgtc ZJ Grand Cherokee Forum 2 10-10-2006 03:43 PM
