with SYE how do you adjust pinion on WJ? - JeepForum.com
post #1 of 2 Old 06-22-2010, 04:31 PM Thread Starter
Mighty Thor
This Question is purely academic for me at this time cause I am not going to do this to my WJ in the foreseeable future, but... I have a ton of experience with leaf spring vehicles but on these coil rigs, if you put in a SYE and a constant velocity drive shaft, how do you adjust the pinion angle without readjusting the axle spring pad? On leaf setups you can shim the perch. Is there a similar shim for coils?
Is that supposed to look like that?
Mighty Thor is offline
post #2 of 2 Old 06-22-2010, 05:03 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
You only have so far you can go before you need to cut and weld. You adjust by control arm length.
The driveline is plenty long enough that you shouldn't run into seating problems with the springs though. Most don't need an sye because of the same reason.
ratmonkey is offline
How to adjust TV cable? SouthSeaPirate ZJ Grand Cherokee Forum 9 02-22-2017 12:39 AM
5.2L Timing. How do you adjust it? gidkid ZJ Grand Cherokee Forum 2 11-30-2007 11:53 PM
What will i need to adjust? wheelNC93 ZJ Grand Cherokee Forum 3 08-23-2007 02:36 PM
how to adjust idle? team510 ZJ Grand Cherokee Forum 4 07-30-2007 10:47 AM
How to adjust Toe? zjeepin ZJ Grand Cherokee Forum 13 10-09-2006 06:46 PM
