Swaping in a D44, new drive shaft needed? - JeepForum.com
post #1 of 5 Old 06-17-2010, 12:39 PM Thread Starter
Mighty Thor
I am replacing the broken Dana 35 in my WJ with a D44 from a newer WJ can I use my current drive shaft or do I need to get a new one?
Is that supposed to look like that?
Mighty Thor is offline
post #2 of 5 Old 06-17-2010, 12:53 PM
TJSWJ
I believe you can use your stock one it just needs to be shortened 1.5inches I think.
TJSWJ is offline
post #3 of 5 Old 06-17-2010, 04:28 PM
jamnjeep
yea, you will need to shorten the ds. With my 3" lift I had to have mine shortened 1 1/8". It was like 50 bucks at the local ds shop
1994 YJ under construction....
jamnjeep is online now
post #4 of 5 Old 06-22-2010, 11:37 AM Thread Starter
Mighty Thor
I will be delivering the driveline to the shop today, Since I do not have a lift I will be taking out 1.5 inches. If anyone has a different opinion I would rather hear it sooner than later. And to the above posters, thank you.
post #5 of 5 Old 06-22-2010, 04:17 PM
vwmaniacx
The first shaft I did I took a whole 2'' out... to much. the 2nd one I only took out 1.75.. IMO still to much. I should have just measured and trusted myself(I did measure, but didn't trust).. i think 1.25 would be perfect. 1'' might even be enough, when I did my measuring it seemed to only be off by a u-joint cap.. which is 1.062.
Hope it helped..sorry if i confused you..lol
you can go a long way with a smile . You can go a lot farther with a smile and a gun . -Al Capone
vwmaniacx is offline
Replacing WJ Front Drive Shaft with Junkyard Shaft? Jonny5alive ZJ Grand Cherokee Forum 4 03-13-2011 10:53 AM
Replacing the front drive shaft (CV) to a U-joint style shaft? Bryson ZJ Grand Cherokee Forum 1 08-12-2007 10:17 PM
swaping front drive shafts IronManVa ZJ Grand Cherokee Forum 29 06-22-2007 11:56 AM
Drive shaft problem front diff info needed??? Kalisto2k1 ZJ Grand Cherokee Forum 3 01-25-2005 03:40 PM
