suspension PROblems coils springs, shocks, sounds like im hitting rocks oh my!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > suspension PROblems coils springs, shocks, sounds like im hitting rocks oh my!!
This is a shout out to all INTERNATIONAL Customers! Yes weEngo winches available at www.rockridge4wd.com! Free shipp*VOTE NOW Help Metalcloak Giveaway an XJ Suspension*
Unread 07-09-2014, 08:41 PM   #1
02grandy
02grandy's Avatar
Wj suspension PROblems coils springs, shocks, sounds like im hitting rocks oh my!!
so I just put on new tires Michelins ltx ms/2 . I just did rear dorman lower control arms and an omxi upper control triangle arm thing with a new mopar ball joint for the center. also did which I think to be are crappy Monroe sensatrac shocks last spring or fall. 2002 jeep grand Cherokee 4.0 113k on it 4x4 selectrac. I think the coil springs are shot all around . my left front is more bouncy then my right front . didn't play with the back but it feels like coil springs are next.i think I want to change to better shocks also.
should I go with mopar coil springs or will the moogs do just fine???
mopars are close to a $100 each for fronts rears looks like $50 each on ebay moogs I can get $100 a pair roughly
should I replace all rubber coil spring insulators even if they are still soft and not broken? I would need 8 . 2 for each what brand is good?
02grandy is offline   Reply With Quote
Unread 07-09-2014, 09:15 PM   #2
02grandy
02grandy's Avatar
how do I find out what springs I have on..... im looking at wjjeeps.com and it looks there could be several options for front or back
Unread 07-10-2014, 07:23 AM   #3
ChrisHager
ChrisHager's Avatar
'Bouncy' would most likely be an effect of blown shocks. Shocks are present to dampen the up and down motion of your vehicle.
That would probably help quite a bit.
I honestly don't really know which is preferred...
I would. They compress over time causing added noise and a lowered ride height. Talk to Kolak. He can send you all 8 for a reasonable price.
I'd request your build sheet from jeep. That should tell you if you have the UpCountry or the standard suspension. To do so, click HERE then click on Equipment Listing on the left.
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
ChrisHager's 'Grilled' Thread
WJ Torque Specs
Originally Posted by tommyooooooh View Post
But ChrisHager makes me want to poor water on a burning bucket of gasoline now just out of curiosity.
Originally Posted by billzcat1 View Post
The latest lift kit from Rough Country? :D
Originally Posted by Jeeples View Post
Your symptoms sounds just like what it does when it's not doing what it should because of how it is.
ChrisHager is offline   Reply With Quote
Unread 07-10-2014, 08:24 AM   #4
Jrboarder27
"Hey Sheldon don't you think you should let some else answer a question?"
Jrboarder27 is offline   Reply With Quote
Unread 07-10-2014, 09:45 AM   #5
ChrisHager
ChrisHager's Avatar
Hahaha! I figured while I'm at it, may as well take care of it here and now.
Hers: 2000 TJ
WJ Torque Specs
Unread 07-10-2014, 09:55 AM   #6
Jrboarder27
I hope you know were I got that quote
Unread 07-10-2014, 09:56 AM   #7
ChrisHager
ChrisHager's Avatar
I'd assume Big Bang Theory...
Hers: 2000 TJ
WJ Torque Specs
Unread 07-10-2014, 11:58 AM   #8
Jrboarder27
OK good!
Unread 07-10-2014, 01:28 PM   #9
multmigs
2003 WJ
Sounds like you want to change springs, why not use the Moog Up Country spec ones which will make you sit a full 1 Inch Higher! They are about $70 a pair shipped to you from rockauto.com and have a factory ride quality. Change the rubber spring pads while you have it apart and you will likely get closer to 2" more.... The shocks does sound like your issue though from your description. Did you remember to tighten the control arms with the wheels back on the ground and weight on them?
multmigs is offline   Reply With Quote
Unread 07-10-2014, 02:03 PM   #10
02grandy
02grandy's Avatar
how about the triangle control that one too or just the two straight rear lower controls?
Unread 07-10-2014, 02:04 PM   #11
02grandy
02grandy's Avatar
where do you get the build sheet?
Unread 07-10-2014, 02:17 PM   #12
02grandy
02grandy's Avatar
are the mopar blue shocks they say are the BULK ones the same as the black ones and what tech is that mono tube or twin tube?
Unread 07-10-2014, 02:20 PM   #13
02grandy
02grandy's Avatar
opps or just a straight gas shock with nitrogen you experts tell me
