Surging rpm/near stalling - JeepForum.com
post #1 of 10 Old 11-07-2015, 12:23 PM Thread Starter
jeep1987
I have a 2000 limited with the 4.7 and 100k miles.
Almost every time Im coming to a stop and the jeep makes the final downshift, the rpm will jump up above 1k and then drop down to about 400 then bounce back up and down before settling around 600. When it drops down I can feel the engine shudder.
It has also done it when I was sitting at the drive thru with the brakes applied and it does it when I stop and shift to park. When I was in the drive thru it just dropped down to about 300 and shuddered.
Any ideas? I have a video I will post later tonight.
jeep1987 is offline
post #2 of 10 Old 11-07-2015, 06:39 PM
madlypat
Any codes? I would suspect the TPS
madlypat is offline
post #3 of 10 Old 11-07-2015, 08:14 PM Thread Starter
jeep1987
No and I forgot to say I cleaned the IAC, replaced the TPS, cleaned the throttle body, and changed spark plugs cause I just bought it.
jeep1987 is offline
post #4 of 10 Old 11-07-2015, 08:52 PM
99SK04GTX
Keep a look out for vacuum leaks, split hoses
99SK04GTX is offline
post #5 of 10 Old 11-27-2015, 07:56 AM Thread Starter
jeep1987
Any have any ideas? It seems to be getting worse. Same jump and fall of the rpm when come to a stop and it makes the final downshift. The near stalling when parking is worse. When I go to park and shift from drive to park the rpm almost always jumps up to near 1500 then straight down to about 300. When it drops it will hold around 300 while trying not to shut off, then hop back up to regular idle.
jeep1987 is offline
post #6 of 10 Old 11-27-2015, 08:49 AM
Redbaron1973
chasing the same thing here..
it pretty much has to be Vacuum but haven't yet found it...
Redbaron1973 is offline
post #7 of 10 Old 11-27-2015, 09:06 AM
86cj74.2L
86cj74.2L's Avatar
Do you have a scanner that reads live data? If so watch the TPS position when it does it knowing your not touching the throttle.
86cj74.2L is online now
post #8 of 10 Old 11-27-2015, 03:46 PM Thread Starter
jeep1987
I don't have one but may be able to find one
jeep1987 is offline
post #9 of 10 Old 12-01-2015, 01:13 AM
ApexBeatz
I read a while back that reflashing your pcm at the dealer fixes this. Mine does it sometimes but just drops down then pops back up
ApexBeatz is offline
post #10 of 10 Old 12-01-2015, 05:47 AM
mr312712
My 04 H.O. does It to when I come to a light. Been doing It ever since I got It, It's never stalled, so I try to Ignore It.
It doesn't matter If the guy next to you doesn't know your racing winning Is winning.
Castrol Edge 10W30 Full Synthetic
04 WJ Overland Inferno Red 4.7 MAGNUM V8 HIGH OUTPUT
mr312712 is online now
