Submit your WJ pics *READ THE RULES PLEASE* - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Submit your WJ pics *READ THE RULES PLEASE*
Savvy Aluminum Gas Tank SkidFS: Jeep Fog Light LED Bulbs! Several Brightness Options! Stainless Steel Door Hinge Pins
Unread 02-01-2011, 05:21 AM   #106
Big-Z
thanks!
Big-Z is offline   Reply With Quote
Unread 02-01-2011, 12:43 PM   #107
Blue70
6" home made long arms, with 31x10.5x15 tires, on 15x8 soft 8s with a 4" back spacing..
Blue70 is offline   Reply With Quote
Unread 02-01-2011, 12:59 PM   #108
JerzeyBoyWJ
2003 WJ
i like those headlight
dub looks sweet it has a perfect flow
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote
Unread 02-01-2011, 01:01 PM   #109
nickc50310
2" Fat Bobs BB. 30.5" Goodyear Wrangler Duratracs. Overland Upcountry Suspension.
Little flex on a snow drift.
nickc50310 is offline   Reply With Quote
Unread 02-01-2011, 09:22 PM   #110
Trevino
99 WJ V8 4.7
Lift - 6" Clayton Long Arm Lift w/ JKS adjustable track bar and quicker discos, front and rear Bilstein 5150 shocks with bar pin eliminator, Rancho steering stabalizer (not a noticable upgrade but smashed old one and this was in stock)
Tires - 33x12.5 Baja Claws
Wheels - Cragar soft 8's 15" with 4" backspacing and spidertrax 1" spacers (cleared the caliper just fine with the spacers, with out just barely. I wanted the spacers for peace of mind)
still need to do some trimming and install Iceland flares the ill do bumpstops and save for some 35's
front
side
flexing
need some trimming and bumpstops, the tire that tucks up has some serious rub
Last edited by Trevino; 02-01-2011 at 09:35 PM.. Reason: added info wasnt sure if pics came out
Trevino is offline   Reply With Quote
Unread 02-02-2011, 06:07 AM   #111
Big-Z
Nice ^
Unread 02-02-2011, 02:04 PM   #112
Big-Z
265-75-16 good year authority on 16''x8'' with 5'' back spacing black rock Lobo style wheels
4'' hybrid lift
cheap rough country shocks (and yes, they are rough)
front bumper cover off for now because I am trying to fix my cooling fan, and I am going to soon build a bumper.
enjoy
(sorry for not posting my flex shot, my computer is not letting do more than one photo. I will post it some time.
Unread 02-06-2011, 07:00 AM   #113
WJRON351
3" IRO Coils
Pro-Comp MX-6 Shocks
IRO adjustable front lower control arms
3" IRO sway bar links (front and rear)
IRO A-arm spacer
2" front/rear bumpstops extensions
16x7 Cragar (4" backspace)
235/85R16 BFG KM2 (32"x9")
Trimmed the wheel well and 1" of bumper under the fog lights, no more rub
Flexing with the AT's on (same size as the KM2)
WJRON351 is offline   Reply With Quote
Unread 02-11-2011, 07:19 PM   #114
zjzach
http://www.jeepforum.com/forum/f197/...thread-970298/
don't know if anyone wants to somehow merge this in or make it its own sticky but i thought id try and move it over here
my build/wheelin/picture thread
http://www.jeepforum.com/forum/f197/...green-1370981/
zjzach is offline   Reply With Quote
Unread 02-11-2011, 08:10 PM   #115
JeepWJ26
So is a Budget Boost basically spacers that gives the Jeep a lift? If I were to get a budget boost and upgrade my shocks, would the ride be good on the road or will it be rough like some of those other body lift kits used out there. Thanks in advance
JeepWJ26 is offline   Reply With Quote
Unread 02-12-2011, 06:30 AM   #116
hick2087
1994 XJ Cherokee
What happenend to my Jeep? I can't find it....
hick2087 is offline   Reply With Quote
Unread 02-12-2011, 06:43 AM   #117
robd2003
you physically simply can not put a BODY LIFT on a WJ. Just simply cant
it is a unibody chassis just like your cars now-a-days, and yes it will handle just fine with Budget Boost 2'' spacers and some good shocks. if you cheap out on shocks the ride is horrible, as is you get what you pay for...
And My contribution for the day sorry no flex havent clearnenced some metal with BFH.
4" RCX-Series with el cheapo shocks<SUCKS! 265/70R17 Fierce Attitude M/T with Dick Cepek DC-2's in 17x9
2/12/2011
Front Sway Bar Connected
Front Disco'd
Jeeps:
99' XJ<->5.5" Lift; 35's; SYE; Winch; much more goodies too
02' WJ<->Rebuilt from wreck, still stock
robd2003 is offline   Reply With Quote
Unread 02-12-2011, 10:16 AM   #118
Akrobatiks
Wj
Got some new photos last week outside of Soldier Field, in the snow, and with my new headlights....
Specs:
- 4" Rough Country X-Series lift
- 2.2 series shocks
- x-flex control arms
- 2.2 series Dual Steering Stabilizers
- 17" Fuel Hostage Wheels
- 265/70/17 Goodyear Wrangler Duratracs
- A few inches of trimming required to minimize rubbing however they still rub a bit occasionally on the back of the factory fogs, its annoying but not serious
- planning on removing and maybe replacing fogs to eliminate the problem
2001 WJ Limited 4.7L Black on Black --- [B]Interior Modifications...[/B] Alpine INA-w900 navigation unit, 2 9-inch headrest LCD's, Alpine PDX-F4 125w x 4 Multi-channel Digital amplifier, Alpine Type - X Component Interior Speakers, Alpine PDX-M12 1200w x 1 Digital Mono Sub Amplifier, 2 MTX - 9510's, Custom built subwoofer enclosure, Sirrius Satellite Radio, Backup Camera, Viper 5901 Remote start/alarm, Passport Escort 9500ci Radar Detector/Laser Shifter, Optima Yellow Top Battery, Cobra 29 LTD BT CB Radio --- [B]Exterior Modifications...[/B] 6" Clayton Long arms, Bilstein 5100's, Addco Front and Rear Sway bars, IRO extended rear sway bar links, JKS Trackbar, JKS quicker front disconnects, IRO front upper and lower coil retainers, Rough Country Dual Steering Stabilizers, 17" Fuel Hostage Wheels, 285/70 Goodyear Wrangler Duratracs, Westin Safari bar, PIAA 525 dual beam off road lights, CCFL Halo Projector Headlights w/ Super Vision 6000k HID bulb kit, 100w PIAA 4000k halogen high beams, LED 360 Amber LED signal bulbs, LED Tail Lights, Jet Accu-Speed Computer chip, Flashpaq jeep power programmer, AVS rain gaurds, Yakima 4 Snowboard rack, Curt tow strap receiver mount, Hornblasters Shocker 240 Train Horn Kit, Rigid E-Series 40" LED light bar, Mean Green H.O. Alternator, JCR Stage 3 Sliders, Blue Torch d30/d44a diff covers, KOR Steath rear tire carrier/bumper. LSR winch mount front bumper, Warn xd9000, KOR under Belly skid...
[CENTER][URL="http://www.jeepforum.com/forum/f197/akros-2001-wj-build-1132013/"][B]Akrobatiks Build Thread[/B][/URL][/CENTER]
[CENTER][SIZE="4"][B][URL="www.jamielinkphotography.com"]www.jamielinkphotography.com[/URL][/B][/SIZE][/CENTER]
Akrobatiks is offline   Reply With Quote
Unread 02-12-2011, 05:10 PM   #119
Blkdvll
Rustys 2.5". Removed front sway bar. 245/75r16 ATs on 16x8 Soft 8's, 4.25bs.
2004 4.0L w/242 WJ - Front tow points, Rear D Shackel, 3"/2.5" lift, 245/75 Falken ATs, Sway Bar delete, Overland Sliders, T-Case Skid, Hella 500's, Halved Bumper, Custom Rad.Core Skid, Soft 8's, MV50 OBA, Hi-lift/lift mate, shovel, (1st)On-Board Cooler, OME S.S., Rola Basket.....more soon
Blkdvll is offline   Reply With Quote
Unread 02-14-2011, 11:19 PM   #120
HaViiK
Way to read the rules guys!
[SIZE="2"][COLOR="DarkRed"]Steven, New HaViiK[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f197/haviiks-01-wj-slow-build-1067820/"][COLOR="DarkRed"]Black HaViiK:[/COLOR][/URL] [COLOR="DarkRed"]2001 WJ, 4.0, 42re (rebuilt at 100k), 30/35, Rough Country X-Series, JCR Stage 3 Sliders, Yakima Megawarrior & Big Powderhound, Grille Guard, KC Daylighter 130w, Custom Sub Box & 2 Kicker 12" CVR
[/COLOR]
[SIZE="2"][URL="http://www.jeepforum.com/forum/f13/zj-wj-faqs-read-first-contact-mod-changes-additions-591821/"][COLOR="DarkRed"]WJ/ZJ FAQ[/COLOR][/URL][/SIZE]
[SIZE="2"][URL="http://www.facebook.com/steven.T.wright"][COLOR="DarkRed"]Facebook. Wheeling stuff in there.[/COLOR][/URL][/SIZE]
[SIZE="2"][URL="http://www.youtube.com/user/Thunderheadrcx?feature=mhee"][COLOR="DarkRed"]Youtube Channel. GoPro/Wheeling stuff[/COLOR][/URL][/SIZE]
[QUOTE=rulppa(chat);10944366]whats with people (steve) with those monster sigs. reply is usually like ':E' then 2 pages of signature lol[/QUOTE]
[QUOTE=Sarahdactyl;11226293]THE WINNER IS REDHOTCHILIDOG!!!!111!!1!!!!(OBNXIOUS HUGE BEEFSTEW STYLE FONT) I will PM winner for details[/QUOTE]
HaViiK is offline   Reply With Quote
