Submit your WJ pics *READ THE RULES PLEASE* - Page 46 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Submit your WJ pics *READ THE RULES PLEASE*
Labor Day Sale!FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitEngo winches available at www.rockridge4wd.com! Free shipp
Unread 06-17-2013, 08:55 PM   #676
lance-tek
Originally Posted by Jaysun1994 View Post
Is there a way to get the color matched grill without the chrome rings like this one. I cant find any online?
on the limited's the bumper and the grille were attached to one another and color matched to the body. On the Laredo they are separate (and the grille is chrome).
I will eagerly accept any advice or help I can get. | Built Not Bought # 736
lance-tek is offline   Reply With Quote
Unread 06-17-2013, 09:19 PM   #677
cde02ltd
I believe the 99 to 2001 limited models did not have the chrome inserts in the grill. Our 02 limited has color matched grill with chrome inserts.
cde02ltd is offline   Reply With Quote
Unread 06-18-2013, 04:06 AM   #678
-OIIIIIIIO-01
2001 limited has body match color with the Chrome rings.
-OIIIIIIIO-01 is offline   Reply With Quote
Unread 06-18-2013, 07:45 AM   #679
brouwmat
brouwmat's Avatar
http://www.wjjeeps.com/grilles/grillesrem.htm
This link has a ton of info on the WJ including everything you ever wanted to know about grilles.
I believe you could replicate this look by painting a stock chrome Laredo grille from 99-03 if you have any other model. The other grilles would have that ridge around the outside that even if you painted it would still be there. Sand it down well with med and then fine sandpaper first (after you take out the black inserts) and it should hold paint decently. There are a ton of pages out there on line that describes how to do this.
Good luck and post pics when/if you decide to do it.
brouwmat is offline   Reply With Quote
Unread 06-18-2013, 10:42 AM   #680
Jaysun1994
thanks for the help I might get a chrome one then and color match it to my wj because i hate the chrome rings so much.
Jaysun1994 is offline   Reply With Quote
Unread 06-18-2013, 11:05 AM   #681
PAJeep6
I may be wrong, but I believe you can just remove the chrome rings. I've see them for sale separately from the grille. I have been wanting to remove mine too, but just haven't gotten around to it yet.
02 Silverstone WJ Limited - 4.7 V8 | JK Moabs w/ 1.5" spacers | 265/70/17 Goodyear Wrangler Authority tires | 3" Powerstick chambered exhaust | 4" lift | IRO adj. trackbar | Rough Country 2.2 shocks | 6000k HIDs in the headlights and foglights | tinted tail lights | TJ gas filler bezel...
PAJeep6 is offline   Reply With Quote
Unread 06-18-2013, 02:47 PM   #682
Russell84
2003 WJ
Originally Posted by wjjeepman34 View Post
Why did this thread lose it's "sticky" status???
I'm assuming because nobody bothers to follow the rules of the thread anymore. Just a guess, though.
-Rusty
2003 WJ Overland 4.7 HO, Clayton Long Arms, Teraflex 4.5" coils, JKS adj trackbar, JKS Quicker Discos, 17x9 Eagle Alloy Series 185, 285/70/17 BFG KM2, cut fenders/bumpers
Russell84 is offline   Reply With Quote
Unread 06-18-2013, 03:47 PM   #683
adavis39
you CAN remove them, but it will look like crap. they are held in with little clips thats you have to brake to get them off. You would be left with little holes around each grille "loop". Best bet is to find a 99 or 2000 limited at the junk yard and cut the grille from the bumper......then just bolt it on to your laredo. Its easy to cut and youll never notice. I cut my grille so that I can run without the bumper on the trail. once you put the bumper cover back on you never notice it ever been cut into 2 pieces
2002 WJ Limited [B]4.7[/B]: 6" Clayton REALLY long arms....yep, they are longer than yours [B]SOLD : ([/B]
1998 Platinum [B]5.9[/B] DD
2007 WK Overland [B]5.7[/B] wifes DD
TNJEEPS.COM
BUILD: [B][url]http://www.jeepforum.com/forum/f197/utwj-build-other-crap-1399123/[/url][/B]
[B]"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"[/B]
adavis39 is offline   Reply With Quote
Unread 06-18-2013, 05:48 PM   #684
Jeep99wj
Jeep99wj is offline   Reply With Quote
Unread 06-19-2013, 07:24 PM   #685
rloew275
rloew275 is offline   Reply With Quote
Unread 06-24-2013, 06:06 PM   #686
evilcairn
Because Beer > Mud
WJ 2001 V8 , 6.5" lift IRO , 35" BF , Front DS TomWoods mutilCV, Fender Iceland, TrueTrac Eaton Front, Gears 4:56 , Custom Front bumper, custom rock slidder ....
evilcairn is offline   Reply With Quote
Unread 06-25-2013, 02:36 AM   #687
ADragg
2003 WJ
My Jeep is finally cool enough to post pictures of!
Pointless barely flexing picture...
3.5" lifted '03 Limited Quadra Drive WJ - OME HD coils, Bilstein 5100 shocks, JKS track bar, IRO extended links, OME 10mm spacers, Moog SS, JK Moab wheels w/ 265/70/17 (32") Goodyear Duratracs.
ADragg is offline   Reply With Quote
Unread 06-26-2013, 06:07 PM   #688
wjjeepman34
04 WJ 4.7 V8-Fully loaded, K&N FIPK, V-force muffler, Duratracs, OME HD coils, Bilsteins, JKS track bar, JKS quicker disconnects, IRO aux mounted SS, Rear sway bar delete, Custom winch bumper.
wjjeepman34 is offline   Reply With Quote
Unread 07-02-2013, 09:49 AM   #689
JustStew
New pic:
4" IRO
265/70 MTZ
JKS QDs
JustStew is offline   Reply With Quote
Unread 07-02-2013, 11:27 AM   #690
pkess3
Nice looking WJ!! We should hit the trail together sometime. I'm in Henderson and have a similarly modified 04 Overland.
pkess3 is offline   Reply With Quote
