Submit your WJ pics *READ THE RULES PLEASE* - Page 17 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Submit your WJ pics *READ THE RULES PLEASE*
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDan's Old as Dirt Birthday Sale!GEARSHADE Pocket Tops in stock and available at ROCKRIDGE
Unread 03-06-2012, 12:14 AM   #241
BlingBlingZJ
Here's mine
Its an 02 limited V8 2WD
3" exhaust with 40 series flowmaster
stock wheels
its a street jeep for now
2002 Grand Cherokee Limited-22's-HID Projector Headlights-40 Series FlowMaster-Airaid Intake-
BlingBlingZJ is offline   Reply With Quote
Unread 03-14-2012, 09:42 AM   #242
Virge
99 WJ Limited V8 Quadradrive
3" IRO Lift
265/75/16 BFG Rugged Trail T/A
Sorry no flex pic yet....
Virge is offline   Reply With Quote
Unread 03-14-2012, 08:44 PM   #243
USFORCES
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline   Reply With Quote
Unread 03-28-2012, 03:57 PM   #244
MURDEREDWJ
Washed, clay barred, and waxed!
Stock wj v8
Engine enameled grille
Engine enameled rims
Stock full skid plates under
Ionic predator bull bar
Hella black magics
New style headlights
ZxE headlights (love them)
VHT rears
K&N drop on
265/70/16 Destination A/T's
BB this summer$$
**MURDER IT**
MURDEREDWJ is offline   Reply With Quote
Unread 03-28-2012, 06:41 PM   #245
4x4Jeep
2" coil spacers
Rancho SS
stock shocks
stock wheels & tires 225/75/16
01 WJ, D30, D44a, 3.73 - 4" RC-X * 32" MT's * IRO adj. trackbar * Uniden CB w/ 4' Firestik * KC/Rigid lights * "Kolak" Flowmaster 70 exhaust *
Build-http://www.jeepforum.com/forum/f197/4x4jeeps-build-thread-1341031
Florida4x4.org
4x4Jeep is offline   Reply With Quote
Unread 04-05-2012, 11:21 PM   #246
nhcd538
2" Budget boost (everything else stock)
265/75/15 Wild Country APT tires
Jegs black d-window rims, 15x7 (4" backspacing) w/ factory JK center caps
Before:
After:
2001 WJ Laredo 4.0L 42RE NV242
nhcd538 is offline   Reply With Quote
Unread 04-09-2012, 07:49 PM   #247
MatthewWJ
Wj 2001 WJ IRO 3" w/.75 bb adjustable upper and lowers
2001 WJ IRO 3" w/.75 bb adjustable upper and lowers, ss, adjustable tracbar, Doetsch Tech shocks. 17" XD wheels and 265x65 17 General grabbers (almost 32" tires). and an updated Double cardian front drive shaft from Tattons.
MatthewWJ is offline   Reply With Quote
Unread 04-12-2012, 07:40 PM   #248
musicpuppy
Wj
Originally Posted by justn View Post
Stock height, stock wheels, stock tire size 225/75/16 BFG LongTrail T/A Tour's.
wow sir, the agony of defeat, not good for this site, but love the honesty.
musicpuppy is offline   Reply With Quote
Unread 04-12-2012, 07:44 PM   #249
musicpuppy
Wj
Originally Posted by USFORCES View Post
04 Overland 4.7 H.O paid $4k out the door... but I had it repainted and did a lot of work in replacing worn out parts from the ground up.
Lifted with IRO 6.5" all adj. then a complete whole new suspension ball joints, bearing, axles you name it.
33" BFG 285/75/16 on MB offroad rims.
EBC brakes and rotors
New brake calipers (complete calipers)
Bliston 5150's
Front & Rear Addco swaybars
H.I.D lighting and H.I.D lens with matching rear tail lights.
Brand new in the box factory nav unit, only reason is I got it cheap!
1/2 thick 2 1/2 qts. (over stock) trans pan plus new oil pan.
All new fluids brakes, power steering, transfer ect ect..
Complete new exhaust system.
Higher cranking battery.
New plugs, belt, intake system.
New rebuilt 242HD 6pinion, installed selec-trac shifter assy.
New spring isolators
Sorry no flex photos, I'll update it soon
Is photoshop great or what...
Update 1/29/12, 242HD with the hummer 6pinion planetary installed.
Below and above, you guys have some sweet WJ's!!
Great lookind ride my friend, and the photoshop aint bad either, but id rather have the ride. lol
Unread 04-12-2012, 08:49 PM   #250
fourninetwo
20" Fuel Offroad Wheels
33's Nitto Terra Grapplers
fourninetwo is offline   Reply With Quote
Unread 04-13-2012, 06:03 PM   #251
aleet25
2003 WJ
2003 WJ Laredo
2" OME HD Springs
2" Daystar Spring spacers
265/75/R16 ProComp Extreme Mud Terrains
aleet25 is offline   Reply With Quote
Unread 04-14-2012, 09:02 PM   #252
Jacko84
I'm still on stock suspension and tires but I saw this rock and couldn't resist...
Jacko84 is offline   Reply With Quote
Unread 04-19-2012, 11:09 PM   #253
snobrdrkid07
Mr. WJ
snobrdrkid07's Avatar
Snobrdrkid's WJ
Current Specs:
Suspension - Stock with 1 inch spacers on all 4 corners.
Stock Rims with 245/70/16's (Second set of rims are 235/65/17's)
Some crappy shocks. Sadly the suspension is still stock. But I still have fun!
Little Bit of Flex
With the OME HD's on!
~ 04 WJ 4.0 | Selec-Trac 242 | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Custom Front D.S. | Stillen Rotors/Metal Matrix Pads | Tow Package w/ 3.73's | Projectors w/ 55w HID H1 5000K Lows | Sylvania Ultra 9005 Fogs | Moog HD Steering | Kenwood eXcelon Radio | Memphis Speakers | Alpine Amps | Alpine Subs | Moog STB SS | Superchips Flashpaq | Auxiliary Transmission Cooler | Rock Lights | Light Bars ~
~ Snobrdrkid's "Build" Thread ~ YouTube Channel ~ Fuelly ~WJ 4.0 Transmission Cooler Info ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | 2" Spacer Lift | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
For Sale:
Front XJ/TJ 2" Budget Boost. PM for details.
snobrdrkid07 is offline   Reply With Quote
Unread 04-20-2012, 12:04 AM   #254
Cirruslydakota
2" BDS/Billzcat lift combo. (2" springs with 3/4 spacers on the front to level it out)
245/75/16 Kumho KL78's on JK steel wheels. Summer tires are Michelin LTX 245/70/16 on stock trashed Timberlines.
Shocks are advance auto Monroe specials with a lifetime warranty. Theyre junk.
Bear - 1999 Jeep Grand Cherokee Laredo - 250,000 Miles, BDS 2" lift, Overland rock rails, Dynomax cat back exhaust, 245/75/16 Kumho KL78's, Rebuilt 4.0 @ 244,000 miles.
Apollo - 2008 Mazdaspeed3 - Mazdaspeed CAI, Mazdaspeed CBE, Prosport boost gauge.
Velvet - 2005 Ford Focus ST - Wife's ride
Cirruslydakota is offline   Reply With Quote
Unread 04-21-2012, 02:00 PM   #255
04dubjay
Thought you guys may enjoy this!!! Might get flamed but whatever...
Then...
[img]
and now...
[img][/img]
2004 Columbia Edition WJ (I6/Selectrac) -{RC/Ironman4x4fab/JKS/KOR/Nitto/Carolina}
04dubjay is offline   Reply With Quote
