Stupid 10 disc changer not spinning CD's - JeepForum.com
post #1 of 19 Old 03-26-2013, 09:48 AM Thread Starter
lazyWJ
2006 XK Commander
My 10 disc changer has been giving me intermittent trouble, which turned into permanent trouble so I finally took it apart. All I'm getting on the head unit is "error". With the covers off, it appears to load the CD, but does not attempt to spin it, it just says error. Everything seems to move freely, and I can turn the disc by hand.
I don't listen to CD's so I'd pull it all together, but I've been using it with my aux input. I have to have a "blank" CD playing in order to use my aux in jack. With no CD changer (or CD, or magazine) I am not able to turn the volume up, only down.
Does anyone know a fix for either ditching the changer altogether but keeping the input mode, or fixing the cd changer? I'm not going to invest money in the changer, if I spend anything it will be on aux the hookup that replaces it altogether. If there's a cheap/easy solution here though I'd love to know about it. Thanks!
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #2 of 19 Old 03-26-2013, 09:56 AM
Merc1973
Search?
Cheap and Easy!
Remove the CD changer from the WJ, get some anti-seize and lightly lube the slides (movable parts) in the CD changer. Reinstall and Viola, it works!
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #3 of 19 Old 03-26-2013, 10:10 AM Thread Starter
lazyWJ
2006 XK Commander
Originally Posted by lazyWJ View Post
SNIP Everything seems to move freely, and I can turn the disc by hand.
/SNIP
The factory grease is still in place and lubricating. Everything loads/unloads as it should. CD just doesn't start spinning once loaded.
2004 Imola BMW ZHP
"Bought, Not Built"
lazyWJ is offline
post #4 of 19 Old 03-26-2013, 10:57 AM
kingmeirl
2003 WJ
http://m.radioshack.com/radioshack/p...egoryId=&path=
Or if you live in Ga you can swing by and have my CD changer. No deck so I don't know if it works. I took it out a few days ago.
kingmeirl is offline
post #5 of 19 Old 03-26-2013, 01:21 PM
Merc1973
"Seems" to move freely? Yeah, I thought so on mine as well. Trust me, give it a shot. I partially disassembled it to grease it. You could even try using lens cleaner on the laser lens.
BTW, the CD changer does not read "Burned" CD's, only originals.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #6 of 19 Old 03-26-2013, 03:02 PM
rdkendrick
2003 WJ
My CD changer will read burned CD's all day. Most of the CD's in my changer are burned copies or mixes. Not sure why your's won't.
rdkendrick is offline
post #7 of 19 Old 03-26-2013, 03:10 PM
Merc1973
Do you use RW+ or - ?
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #8 of 19 Old 03-26-2013, 03:23 PM
rdkendrick
2003 WJ
CD-R's
post #9 of 19 Old 03-26-2013, 03:28 PM
OverlandInRI
I have CD-RW and they work in mine. Although, they didn't with my first attempt. But that was because Windows media player defaulted to 'data CD' instead of 'music CD' when I first burned them. Once I figured that out they work fine now.
OverlandInRI is offline
post #10 of 19 Old 03-26-2013, 05:09 PM Thread Starter
lazyWJ
2006 XK Commander
By "seem" I mean that I can watch the all the cd's load and unload while the case is open. Anyway, from what I've read the changer has a safety interlock so that it won't operate the laser with the case removed, so trying to run it with the case off wasn't going to work anyway. I reassembled it, and after loading the mag twice, it started working again. While burned discs are more finnicky, they work just fine in mine. When it works at all.
I guess greasing the lens helped after all
2004 Imola BMW ZHP
"Bought, Not Built"
lazyWJ is offline
post #11 of 19 Old 06-20-2013, 09:56 PM
JoeFaz
KL Cherokee
Having the same issue with mine ('99). I can hear them all loading and changing, but I get "ERR" each time. Then once in a while it will work as though nothing was wrong. Turn it off and BAM, "ERR" again! ARRRRGGGGHHHHH!
JoeFaz is offline
post #12 of 19 Old 06-21-2013, 04:44 AM Thread Starter
lazyWJ
2006 XK Commander
Since I took it apart and put it back together, other than the first error it's been working OK. I found that removing and reloading the mag seemed to trigger it to work. I tried turning it on and off, and cycling through the cds for a couple days while driving, and it wouldn't work. Then I reloaded the mag a couple times and it worked. Very frustrating for sure.
2004 Imola BMW ZHP
"Bought, Not Built"
lazyWJ is offline
post #13 of 19 Old 06-21-2013, 04:54 AM
Darnice
Is it a direct drive motor or gear/belt driven? Could a gear failed, fell off or a belt gone.
Darnice is offline
post #14 of 19 Old 06-21-2013, 06:22 AM
Double E
Double E's Avatar
It's a known issue with that unit. It will work perfectly for a week and then never load a disc... I've found that if I try to load a CD, then immediately request a track other than letting it start at 1, it will work when it is being problematic. Burned or bought discs are no factor to me either.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #15 of 19 Old 09-10-2013, 05:19 PM
JoeFaz
KL Cherokee
When you say remove the changer, do you mean just the cartrage or take the whole unit (internals) apart?
JoeFaz is offline
