Stumped/Given up. 4.7 Overheating problems - Page 2 - JeepForum.com
post #16 of 23 Old 10-14-2013, 01:32 PM Thread Starter
sage39henry
I should kick myself for this but i believe it was a duralast one. Ha. And thats my plan to my mopar one. Can i only get one at a dealership? Sorry for my lack of education in advance but i am not sure what a bleeder valve is. Could you show me a picture?
WHITE WJ LIMITED 4.7 242HD/ IRO arms w/ Rusty's 4.5in coils/Doetsch 5in Shocks/JKS Quicker Disco's/ D44a Spartan Locker/ Rigid Industries 10" light bar/ 33 12.50 15 Mickey Thompson MTZ/ V-5s
sage39henry is offline
post #17 of 23 Old 10-14-2013, 02:59 PM
Jeeples
Jeeples's Avatar
No problem. Auto Zone IIRC, has two lines of t-stats, Duralast and Duralast Gold (someone correct me if I'm wrong). The Duralast Gold is a repackaged Motorad, which are a pretty good stat as they're 100% stainless steel and have the bleeder valve as well.
As for the Mopar stat, you can either order from one of the whosalers online/Amazon, Kolak here on the forum or locally at the Dealer.
The bleeder valve is also sometime referred to as a jiggle pin, and is the little brass pin pictured below:
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #18 of 23 Old 10-15-2013, 01:47 PM Thread Starter
sage39henry
how does this look to ya guys?
http://www.autozone.com/autozone/par...834_1644_93207
post #19 of 23 Old 10-15-2013, 02:24 PM
Jeeples
Jeeples's Avatar
The general consensus is to stay away from the fail safe stats as they have a tendency to fail rather quickly. Granted you won't be overheating, but you can bring on another set of issues by running too cold for too long.
Jeeples is offline
post #20 of 23 Old 10-15-2013, 05:03 PM Thread Starter
sage39henry
alright, guess ill just get in touch with kolak or something.
post #21 of 23 Old 10-15-2013, 09:16 PM
bgshemi
2003 WJ
jeep overheating
2003 jeep grand cherokee 4.0
My jeep was overheating. The point where the overflow hose goes to the overflow tank on mine was blocked. Apparently from the factory. There was no hole for the overflow to get back in the tank so check yours. Also, the connection to the electric fan on mine went bad and it started to overheat. I cut the connection off and wire nutted it back together. So check to see if your fan is coming on.
That is all I've got.
bgshemi is offline
post #22 of 23 Old 11-25-2013, 01:43 PM Thread Starter
sage39henry
just in case anyone is trolling this thread later on i replaced my water pump whenever i replaced my heater core and everything is in tip top shape. Water pump was toast!!!
post #23 of 23 Old 11-25-2013, 01:50 PM
skain8
skain8's Avatar
Glad you updated your thread. Thanks, and glad you fixed the issue.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is online now
