stuck in parking lot - JeepForum.com
post #1 of 3 Old 10-03-2013, 09:06 PM Thread Starter
Jrboarder27
My upper Radiator hose blew this morning and had to work all day till 6pm,before I could repair it. I got the system drained (had the wrong coolant in it) refilled with zerex g05 and now going through the heat up cool down process on wj jeeps. Do I have to leave parked or can I drive it home and let it cool down and then add coolant
Sent from my Galaxy S4 using JeepForum
Jrboarder27 is offline
post #2 of 3 Old 10-03-2013, 09:40 PM
greeky510
Just drive. Have the heater on high and once in a while raise the rpm above 3000 by lowering gear and run it for like 30 seconds each time.
If you are talking about a long drive make stops to check that the overflow tank is full.
Sent from AutoGuide.com App
greeky510 is offline
post #3 of 3 Old 10-05-2013, 09:23 PM Thread Starter
Jrboarder27
Hey thanks for the help, got home just fine. went back out the next morning and checked everything and went through the hole process
