Stuck in 4lo, help!!! - JeepForum.com
post #1 of 5 Old 07-27-2012, 10:16 PM Thread Starter
AlecBrennen
I have a 2000 grand Cherokee, 4.7 v8, with quadra-drive, so it's in all time 4wd, and I was told to run 4lo once in a while, to keep it lubricated and operational, so I switched over to 4 low, worked fine. But when I wanted to switch back to 4 high, it wouldn't switch, it wouldnt even go into neutral. Any help, please?
AlecBrennen is offline
post #2 of 5 Old 07-27-2012, 10:29 PM
pinky2252s
Theres no reason to use 4lo to "lubricate" anything. The diffs and tc always spin.
Did you put the trnasmission in neutral before putting the tc in neutral? Try lightly rolling the car down a slight hill (less than 5 mph) and put the tranny in neutral and then shove the transfer case in neutral.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #3 of 5 Old 07-27-2012, 11:20 PM
Sohcvtec1995
If your not getting anything make sure the linkages are all attached under the jeep.
Sohcvtec1995 is offline
post #4 of 5 Old 07-27-2012, 11:25 PM
ZB_WJ
Put it in neutral. Don't worry. I did it too :embarrassed:
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #5 of 5 Old 07-28-2012, 01:27 PM
MoparMan1990
1992 XJ Cherokee
I did it too lol
MoparMan1990 is offline
