Stubborn Pinion Nut - JeepForum.com
post #1 of 17 Old 10-06-2013, 07:00 PM Thread Starter
bgohsman
Stubborn Pinion Nut
Happy weekend everyone.
Somehow I have the feeling you've dealt with this at some point.
I can't get the pinion nut off of the yoke on my differential to save my life. I took a long piece of angle iron and made a tool. I was able to put two bolts through the angle iron, into the yoke, and the pinion then couldn't rotate. I beat on it with an impact wrench for about five minutes ( the carriage is out). Didn't budge. Tried a breaker bar with a pipe but only ended up breaking the bolts in the tool.
So, I've soaked it with liquid wrench and am letting it set. The rust is really minimal inside the yoke. The nut looks like new. It just won't move.
Anyone have any ideas or advice? It's going to sit for the week. I'll get back to beating it up this weekend.
Thanks,
Brandon
Brandon Gohsman
bgohsman is offline
post #2 of 17 Old 10-06-2013, 07:26 PM
StormChaserTim
On occasion, I have seen them staked down. See if it looks as if there is a section of the nut pinged down into a recess on the pinion shaft. If there is, take a small punch, and straighten it out. Should come off then.
Tim
1995 Jeep Grand Cherokee Laredo, 4.0L 2WD, 355,000 miles.
StormChaserTim is offline
post #3 of 17 Old 10-07-2013, 12:21 AM
85IrocZ-28
I had to use an 18" pipe wrench on the outside yoke to keep it from twisting, and a 18" breaker bar with socket to get my pinion free. It was tough, the impact gun couldn't remove it.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #4 of 17 Old 10-09-2013, 04:51 PM Thread Starter
bgohsman
Originally Posted by StormChaserTim
On occasion, I have seen them staked down. See if it looks as if there is a section of the nut pinged down into a recess on the pinion shaft. If there is, take a small punch, and straighten it out. Should come off then. Tim
It doesn't appear to be staked. Both the nut and threaded end of the pinion look perfectly round. This weekend, after a week of soaking in liquid wrench, I'll try a pipe wrench and/or the impact gun and breaker bar. The axle assembly is currently on a bench. So it wants to move. Need a couple people to hold it down. Lol
Brandon Gohsman
bgohsman is offline
post #5 of 17 Old 10-09-2013, 05:58 PM
Duh
If you get desperate, pickup a small torch to heat the nut. Assuming a new bearing is going in........
Duh is offline
post #6 of 17 Old 10-09-2013, 09:28 PM
mycreativename
When I did it, I actually used a breaker bar and extension to let it go out past the bottom of the Jeep and then drove it in reverse (or forward, don't remember which is the right way) so that the force of the engine would push the bar against the control arm to break the nut free.
This was after trying 3 different impact wrenches, none of which worked.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #7 of 17 Old 10-10-2013, 02:22 AM
nolimitssjca
I had this problem last week. My 400 ft lb impact wrench wouldn't budge it. I ended up u[grading to a 1000 ft lb torque impact wrench.
1999 WJ 4x4, 1997 ZJ 4x4
1997 Mountaineer 4x4, 1996 Explorer 4x4
1972 Mustang Mach 1 351 Cleveland, 1972 Mustang Coupe 302
1970 Chevy C-20 350, 2002 Kawasaki Vulcan
nolimitssjca is offline
post #8 of 17 Old 10-10-2013, 09:48 AM
Jeeples
Jeeples's Avatar
I've always slipped my 3.5 ton floor jack handle over the end of my 1/2" drive 18" long breaker bar. A generous soak with a little PB Blaster and they come right off.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #9 of 17 Old 10-10-2013, 09:49 AM Thread Starter
bgohsman
I may try this with a propane torch. And, yes, I'm going to replace the bearings while everything is apart.
Brandon Gohsman
bgohsman is offline
post #10 of 17 Old 10-10-2013, 09:51 AM Thread Starter
bgohsman
That is a kind of ingenious solution. Unfortunately, my axle assembly isn't currently on the vehicle, it's on a bench. So I'm stuck using [persuasive] hand tools.
Brandon Gohsman
bgohsman is offline
post #11 of 17 Old 10-10-2013, 09:53 AM Thread Starter
bgohsman
This is actually exactly what I did. I think my problem was my solution for immobilizing the yoke. I made a tool to hold the yoke in place and, instead of breaking the bolt free, I broke my tool. lol. I'm going to try the pipe wrench approach this weekend. I keep soaking it with Liquid Wrench.
Brandon Gohsman
bgohsman is offline
post #12 of 17 Old 10-10-2013, 03:39 PM
Jeeples
Jeeples's Avatar
Gotcha.
Is the axle fully assembled still? If you still have the knuckles and hub assemblies installed (or axle shafts if it's the rear), you could mount the wheels and roll it up against a wall, that way the axle pushes against the wall while you're applying force to the pinion nut.
Jeeples is offline
post #13 of 17 Old 10-10-2013, 07:05 PM Thread Starter
bgohsman
Gotcha.
Nope. Not even ball joints. In fact, the differential carriage is out. The pinion and yoke are the only things on the housing at the moment. But that gives me an idea. Perhaps I could take a couple of U-bolts and bolt it down to the bench...
Brandon Gohsman
bgohsman is offline
post #14 of 17 Old 10-10-2013, 07:39 PM
Duh
Gotcha. Is the axle fully assembled still? If you still have the knuckles and hub assemblies installed (or axle shafts if it's the rear), you could mount the wheels and roll it up against a wall, that way the axle pushes against the wall while you're applying force to the pinion nut.
You learn after the first time to always pop the pinion nut off before anything else
Duh is offline
post #15 of 17 Old 10-10-2013, 07:49 PM
JGC99
A big enough pipe wrench with the correct bite to it worked great for me. 1 and 1/8th socket and as others said a long breaker bar with the end of the jack handle worked great. Best of luck!
JGC99 is offline
