strong vibration when idle - JeepForum.com
post #1 of 2 Old 06-17-2012, 08:47 PM Thread Starter
harricharan
speedometer bouncy a little not much just a little on the highway when you are giving the same gas pedal pressure around 65 to 70 mph, another thing is when the gauges read 0 MPH as soon it hit 0 mph you can feel a strong vibration on the steering wheel any suggest, it this normal for this type of vehicle? 2000 Jeep Grand Cherokee 4.0 2wd with 150k,miles
I don't know if this is related to the problem too my cruise control don't work the light come on on the dash for cruise control but it doesn't engage ...
It got a new TPS sensor BTW
harricharan is offline
post #2 of 2 Old 06-18-2012, 08:55 AM
super98lsc
Codes? Check engine light?
Sounds like a cylinder misfire, many causes for that.
1. Spark Plug fouled
2. bad or dirty injector on that cylinder
3. cracked coil bar or boot
4. bad valve
5. wiped out lobe on the camshaft for one of the valves on the affected cylinder, typically this would get worse under load.
Testing steps:
Scan for codes...then...
1. Check plugs, replace if questionable post pics here ill review them and tell you by the look of them if the cylinders are firing correctly. If one plug appears cruddy, wet, black etc with carbon buildup then its likely the problematic cylinder. So make certain you note which cylinder they are removed from.
2. Compression test all the cylinders (if one is weak then we need to address why) could be as simple as a valve could be as much as a cracked head, or bad head gasket.
3. If plugs and compression test fine then we need to check injectors out. It might have one leaky or sticking injector or one not flowing well and causing that cylinder to run lean.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
Do it yourself matinence to help high mileage wj running strong? MikeJ75 WJ Grand Cherokee Forum 2 02-08-2012 11:42 AM
Vibration at idle 1000-1900 rpm bcurto WJ Grand Cherokee Forum 2 10-09-2011 07:18 PM
Strong fuel smell under the hood!!! Tejasmtb WJ Grand Cherokee Forum 0 11-03-2010 08:16 PM
Suggestions for strong battery (WJ) with power inverter adgjqetuo WJ Grand Cherokee Forum 22 06-04-2010 05:14 PM
WJ rear coil springs - How strong and resistible they are to heavy load? SBrudzinsky WJ Grand Cherokee Forum 7 10-30-2003 09:35 PM
