Stroker build - Page 3 - JeepForum.com
post #31 of 69 Old 05-23-2013, 08:07 AM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
Just picked it up from the machine shop
Machine shop costs:
Valve job: 110
Cylinder head surfacing(.005) 60
Clean Motor 125
Clean Head 30
Install cam bearings 35
Install expansion plugs 25
Rebore block (.030) 120
Press pistons 48
Recondition rods 100
Balance crank, fly, HB 200
Deck block (.003) 100
Install rings 25
Misc 20
Total 998
Ouch.
Knoxes is offline
post #32 of 69 Old 05-23-2013, 08:46 AM
bugaboots
Wow definatly ouch. I am in the middle of building mine into a stroker as well and when all is said and done i should have only like 2 in the complete motor. Thats including 1500 for all my parts(new head included).
1995 Cherokee 4.0 Stock(for now)
2002 Grand Cherokee Sport, OME HD lift, Bilstien 5100's, 63mm Bored t-body, IRO 2.5 exaust, 245/75/16 Revo2, Front tow hooks, 4.6L long rod stroker, Factory Jeep brush gaurd
bugaboots is offline
post #33 of 69 Old 05-23-2013, 09:10 AM
PhantomWJ
2003 WJ
Originally Posted by Knoxes View Post
Machine shop costs:
Valve job: 110
Clean Motor 125
Clean Head 30
Press pistons 48
Install rings 25
Misc 20
Total 998
Ouch.
That not bad.
PhantomWJ is offline
post #34 of 69 Old 05-23-2013, 11:45 AM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
Originally Posted by PhantomWJ View Post
That not bad.
Yeah, I think there's a bit of fluff built in there, but everything needed to be done and it's not like I can do it myself. I'm not thrilled about the costs (I'm a tightwad), but it's money well spent, I guess. Mrs K keeps reminding me that this will cost a lot less than buying Lil K a used car in a year.
Knoxes is offline
post #35 of 69 Old 05-23-2013, 11:53 AM
bugaboots
Might i ask why you chose to go with the 232 crank vs the 258?
post #36 of 69 Old 05-23-2013, 01:26 PM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
Sure - mostly due to pricing. The 232 is about 100 bucks cheaper than the 258. And you can build a stroker with just the crank and pistons. With the 258, you need crank, *rods* and pistons. Also, I can use the stock cam and valvetrain, while the 258 recipes generally call for a (new) higher lift cam, which means new springs, retainers, clips, etc.
Also, I already have a 2004 4.7 HO, so I wasn't looking to build a monster. I was content to just rebuild the 4.0, but thought I could get some cheap power with the mini-stroker recipe. I just want a reliable DD without that dead spot around 2K rpms.
Knoxes is offline
post #37 of 69 Old 06-03-2013, 12:16 PM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
As usual, it's slow going. We had problems getting the fourth piston in - the bottom ring kept getting hung up. So we quit there.
I figure 3 oughta be enough.
Knoxes is offline
post #38 of 69 Old 06-03-2013, 12:30 PM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
BTW, that stand is a POS. I think it's a Torin. The welds are out of line and a freakin mess. As you can see, we had to modify it with some outriggers just to stabilize it. And to think that the seller said that he built a small block Chevy on it. I can't imagine.
Knoxes is offline
post #39 of 69 Old 06-03-2013, 02:32 PM
bugaboots
Got to love seeing some progress, I just got my parts ordered for mine. Hope to have it running down the road by the end of the month, and that will be later than i need.
post #40 of 69 Old 09-04-2013, 06:58 AM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
Lil K doing some lifter installation. It's moving along, but slowly.... I started this project in late December. And it's due for inspection in November!
Knoxes is offline
post #41 of 69 Old 09-04-2013, 05:33 PM
99WJ539918
Looks good. Now hurry up and finish!
Build Thread
99WJ539918 is offline
post #42 of 69 Old 09-16-2013, 07:31 AM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
Pretty sure that pulley isn't in the right place, but I bolted it on mostly to keep from losing it.
Knoxes is offline
post #43 of 69 Old 09-23-2013, 07:30 AM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
Progress...
Knoxes is offline
post #44 of 69 Old 09-23-2013, 07:40 AM
bugaboots
Looking good, looks like you'll have it going sooner than later. If I can make a suggestion, replace anything that is questionable. I already had a big scare with the oil sender on my 4.6 that's got 600mi on it, and bad cooling problems. Its all fixed but would have been easier when I did the install initally.
post #45 of 69 Old 09-23-2013, 12:45 PM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
Thanks - that's great advice. Except that everything's "questionable" on the Jeep!
When I started, I made a decision to replace anything that would require removing the engine to access. That's kind of the event horizon for me.
Knoxes is offline
