Stroker build - JeepForum.com
post #1 of 69 Old 12-28-2012, 08:05 PM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
Stroker build
Decided my backup Jeep needed a rebuild - the 4.0L L6 just doesn't have enough power.
Started yesterday:
Some car porn:
Hood off:
End of day one:
End of day two:
Almost everything is disconnected. I was trying to avoid discharging and removing the a/c system, but I don't think it's possible to pull the engine with the ac lines crossing above and below the front of the motor. That will have to happen next. I think the intake manifold has to come off to get the exhaust pipe free from the manifold. Once those things are done, I guess it's the bellhousing next. Then it should be free to come out. The FSM says to pull the motor without the trans.
It looks like there wasn't much accomplished on day 2, but I got a lot of the little things out of the way - a ton of connectors, the radiator finally came out, fuel rail and injectors, the belt, tensioner, power steering pump, starter, etc.
Trying to figure out where the lifting points are on this engine.
Knoxes is offline
post #2 of 69 Old 12-28-2012, 10:37 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
billzcat1 is offline
post #3 of 69 Old 12-28-2012, 11:27 PM
240impala
2003 WJ
Wait till your at this step haha! I'm currently building a stroker as well
"Don't Do It"
http://www.jeepforum.com/forum/f22/w...there-1153271/
IRO 6.5" lift, IRO Front long arms, rear iro adj upper a arm and adj rear lower, custom 4x4 fab front bumper, rough country winch, 15" crager soft 8's, procomp 35-12.50 tire, fenders trimmed KOR light bar, malone roof rack
240impala is offline
post #4 of 69 Old 12-29-2012, 07:17 AM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
Billz - yeah, good call - although the other inline is much better looking - twin overhead cams, sidedraft SU carbs, big black header...
So where are the lifting points? Do you have to use the head bolts?
Knoxes is offline
post #5 of 69 Old 12-29-2012, 07:31 AM
Cirruslydakota
I know this is heresy but I'd love to shove GMs 4.2 atlas I6 into my jeep. That engine is a beast.
Sent from inside my 4.0.
Bear - 1999 Jeep Grand Cherokee Laredo
Apollo - 2008 Mazdaspeed3
Vivienne - 2015 Chrysler 200S
Cirruslydakota is offline
post #6 of 69 Old 12-29-2012, 10:10 AM
PhantomWJ
2003 WJ
PhantomWJ is offline
post #7 of 69 Old 12-29-2012, 03:36 PM
Cirruslydakota
Come on, who else besides BMW makes (gas) inline sixes anymore? I wish Chrysler had updated the 4.0 six to the tune of how GM created the atlas. Who wouldn't want 290hp and 270tq? Even a jeep lover has to admit that's killer compared to our 190/235.
post #8 of 69 Old 12-29-2012, 03:57 PM
xtremzj
How big of a stroker? Poor man? Or big buck?
98 ZJ 5.5in hybrid long arm/35"TSLs/4.7 Golen Stroker/Kevin's front bumper/TrailReady rear/hp30/d44/4.56/oba/dual battery/rocklights/milemarker9k.Way to much to list.
QuirkWorks Sponsored #44 subaru rally car
CHRYSLER CERTIFIED MASTER TECH. PM IF YOU HAVE QUESTIONS.
xtremzj is offline
post #9 of 69 Old 12-29-2012, 05:09 PM
PhantomWJ
2003 WJ
Yeah it is.
post #10 of 69 Old 12-29-2012, 11:10 PM
billzcat1
2003 WJ
I would have liked to see the I6 evolve with an aluminum head, maybe even go OHC but that wasn't to be with the emissions and crash protection requirements that merited the switch to V6s.
Volvo was making I6s for the XC90 up until very recently, but very few other brands have continued to use the I6. Only BMW and GM that I know of.
post #11 of 69 Old 12-30-2012, 11:10 AM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
This is my plan, subject to change depending on what I find once I break it down:
AMC 232 3.500" stroke crank
Jeep 4.0L 6.125" rods
Silvolite UEM-2229 pistons
Increase piston dish volume to 23cc
8.8:1 CR
CompCams 68-115-4 192/200 degree camshaft
Ported HO 1.91"/1.50" cylinder head
Mopar/Victor 0.043" head gasket
0.040" quench height
Ford 24lb/hr injectors for '87-'95 engines, Accel 24lb/hr injectors for '96-'04 engines, '98 Chevy LS1 25.2lb/hr injectors for '05-'06 engines
241hp @ 5000rpm, 294lbft @ 3000rpm
Knoxes is offline
post #12 of 69 Old 12-30-2012, 11:36 PM
240impala
2003 WJ
8.8:1 CR
Who is dishing your pistons? My issue right now is finding someone who will machine them.
"Don't Do It"
post #13 of 69 Old 12-31-2012, 10:28 AM
WJ2000
Here's some thing I found, http://www.hesco.us/shop.asp?action=...115&catId=7735
2000 WJ 4.0 NEW 4.6 stroker. W/ 4'' Tera Flex Long arm kit, KING 2.5s w/res front,2.5 Kings w/res Rear,Tom wood front drive, 33 x 15s KM2s, Bassett 15'x8 ,fully addjustible Tera flex Track bar, IRO 3link rear, EBC Dippled & sloted front disks, EBC green stuff pads, Iceland off road fender flairs''.
WJ2000 is offline
post #14 of 69 Old 12-31-2012, 10:44 AM
billzcat1
2003 WJ
Yeah, Hesco heads are extremely cool. I just don't know anyone who has had the budget to drop $2k on the head alone.
post #15 of 69 Old 01-02-2013, 07:52 AM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
Monday's progress - discharged the a/c, pulled the condenser, removed about another dozen connectors, removed the valve cover and got 3 of 4 exhaust pipe-to-manifold bolts out. Having real problems with the second bolt on the front pipe. Right now, it's soaking in a half gallon of PB Blaster. I'll take another shot at it this weekend. I think I need an offset box wrench to get under the flange. I couldn't get a good grip on it with a socket.
240 - I'm not sure, but I hope the machine shop that I'm using will do it. I'll let you know. It's about 30 minutes north of Charlotte.
Knoxes is offline
