Strapped spare tire to roof, awesome storage space now! - Page 2 - JeepForum.com
post #16 of 41 Old 11-09-2013, 11:38 AM
gcjeeping
gcjeeping's Avatar
Originally Posted by georged View Post
How many people does it take to get it up there?
All relative to how big a person you are and how strong. I'm 6'3" and 260. I had no problem getting a 33" on a steel wheel up there. Now if you 5'1" and 110 maybe need a couple people.
_____________
gcjeeping is online now
post #17 of 41 Old 11-09-2013, 01:15 PM
Itstime
Originally Posted by greeky510 View Post
I say 2 weeks before it gets stolen.
A really good idea though.
Sent from AutoGuide.com App
Thats what I was thinking you would need some type of lock system. I dont think you could easily come up with anything that would keep it from theft.
Itstime is offline
post #18 of 41 Old 11-09-2013, 03:28 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
Careful with those straps like that, we had our roof rails rip out with a similar setup like that. The tension pulling inward like that, not ideal.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #19 of 41 Old 11-09-2013, 03:55 PM
Darnice
I see it an overland, where are the cross rails. I would at least have the rear one behind the tire. To stop it sliding rearward.
Also, sitting on the roof like that, it will wear the paint away in quick order and rust will start.
Not to mention all the rattle noises on ever bump from the stuff in the spare well.
Get a proper roof mount, do it right.
Darnice is offline
post #20 of 41 Old 11-09-2013, 08:05 PM Thread Starter
PatriotUSMC
Lol, not that heavy. I just picked it up and rolled it up the top portion of the door and laid it down. I'm 6'2" but not exactly muscular.
2002 WJ Overland (Upcountry, 4.7 HO, Quadradrive).
1997 XJ Sport 4" Lift, 31's.
ΜΟΛΩΝ ΛΑΒΕ!
PatriotUSMC is offline
post #21 of 41 Old 11-09-2013, 08:06 PM Thread Starter
PatriotUSMC
That would suck so bad! Well, I don't spend anytime at all in bad neighborhoods, so I'll take you up on that bet!
ΜΟΛΩΝ ΛΑΒΕ!
post #22 of 41 Old 11-09-2013, 08:07 PM Thread Starter
PatriotUSMC
Any chance you will gift me that Surco rack???
ΜΟΛΩΝ ΛΑΒΕ!
post #23 of 41 Old 11-09-2013, 08:08 PM Thread Starter
PatriotUSMC
That would definitely suck! I did notice that the rails do move a bit when I applied tension so I didn't go too tight.
ΜΟΛΩΝ ΛΑΒΕ!
post #24 of 41 Old 11-09-2013, 08:09 PM Thread Starter
PatriotUSMC
For some stupid reason mine doesn't have them. I've been looking into getting some anyways. Just one more thing that I need these days. No rattling from anything in the rear, everything is packed in there pretty tight.
ΜΟΛΩΝ ΛΑΒΕ!
post #25 of 41 Old 11-09-2013, 08:34 PM
gcjeeping
gcjeeping's Avatar
LOL It's been gone for over a year now. I made this to replace it.
_____________
post #26 of 41 Old 11-09-2013, 08:45 PM
Fireball027
I made a mounting bracket for my roof basket, but found it to much of a pain to get it up there and you could feel the extra weight up there on turns. So I got a hitch carrier made and use the spare tire spot to hold all my tools and recovery gear.
Here was my original roof mount bracket. It used a threaded rod with a 3/4 nut welded on top and a factory metal holddown plate.
And here is how it sits now..
Fireball027 is offline
post #27 of 41 Old 11-09-2013, 08:59 PM
Jrboarder27
Hopefully you don't have to slam on the brakes. I watched the very same set up turn really bad. the guy had to slam on the brakes, tire sled out from under the straps and went through the rear window of the the car in front.
Sent from my Galaxy S4 using JeepForum
Jrboarder27 is offline
post #28 of 41 Old 11-09-2013, 09:11 PM
Itstime
That sounds like a bad deal
Itstime is offline
post #29 of 41 Old 11-10-2013, 06:12 AM
WJefy
I did this when I used to have a ZJ. Master makes a cable lock that I ran through the tire and the rack rails. I had mine sitting on the rails. The tire would hop like crazy sometimes. You can't put enough tension on it to keep it really secure without putting pressure on the rails or roof. That being said, a cable lock might keep it from turning into a projectile.
I love the look. I have an '04 Overland and would like to do the same. I am saving to get a rack with a mount before I do, though. Of course I'm also saving for a lift, tires...hmmmm...it may be a while.
WJefy is offline
post #30 of 41 Old 11-10-2013, 08:09 AM
akinshake
akinshake's Avatar
I just strapped mine to two of the cross rails through the spokes. Been up there for about a month now and hasn't loosened up or moved around at all.
99 4.0 Laredo Selectrac, 6.5" IRO long arms front and rear, 35" KM2, 17" Moab JK wheels,IRO transfer case skid, Clayton D44A truss, 4:56 gears and LSD axle swap.
akinshake is offline
