Strange rubbing noise - JeepForum.com
post #1 of 8 Old 03-11-2012, 11:42 PM Thread Starter
chrisf1153
STarting at about 10mph I'm getting a rubbing sound , like a baseball card on a bicycle tire. Seems to be coming from the driver front. Took a look around didn't see much of anything, ideas would be greatly appreciated
chrisf1153 is offline
post #2 of 8 Old 03-11-2012, 11:49 PM
vmo23
inner wheel well liner loose and rubbing?
vmo23 is offline
post #3 of 8 Old 03-12-2012, 12:19 AM
jerrod710
2003 WJ
Do you have stock wheels? If you have wheels with hubcaps maybe you got something that slipped inside the hubcap rattling around. Maybe a prankster got you with the zip tie trick on the drive shaft.
jerrod710 is offline
post #4 of 8 Old 03-12-2012, 02:35 PM Thread Starter
chrisf1153
Lol no zip tie, checked the wheel well everything looks to par. It's defiantly not anything engine related, it only happens when I'm moving. Would brake pad indicators do that ?? It's a high pitch humming driver front help
post #5 of 8 Old 03-12-2012, 04:44 PM
jerrod710
2003 WJ
Maybe. Pull wheels off and check.
post #6 of 8 Old 03-12-2012, 04:48 PM
nhcd538
nhcd538's Avatar
I has a similar problem with my wifes 2006 Commander (XK). Turned out the front passenger disc brake dust shield had corroded to the point of rubbing against the rotor once in awhile. I removed the corroded portions of the dust shield to solve the problem. Just something to consider before you go buying new front end parts.
1999 TJ 2.5L / 2011 WD Durango 3.6L
*Disclaimer - I've probably had a few beers
nhcd538 is offline
post #7 of 8 Old 03-19-2012, 04:09 PM Thread Starter
chrisf1153
Took the wheel off inspected around didn't see much moved some lines around put wheel back on no noise!! Two days later noise is back , did everything I did the other day still making the noise. It's a rubbing noise not metal to metal , I hope one of u guys can make sense of this before I bring it to someone thanks
post #8 of 8 Old 03-19-2012, 05:24 PM
jerrod710
2003 WJ
A 2006? Wow! The shield didn't last very long.
