Strange Oil pressure - JeepForum.com
post #1 of 8 Old 10-10-2013, 07:11 PM Thread Starter
79chiefs
1988 XJ Cherokee
Lately after my recent oil change i noticed that when stopping at a stop sign my oil pressure hits zero. When i am driving it is ~45psi. It only drops when stopping in gear. If i had a bad sender would that not just cause it to not work, and if the pump was bad no pressure all the time?
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #2 of 8 Old 10-10-2013, 07:36 PM
Duh
Can you hear excessive noise from the heads when idling? One of the first signs of bad pressure, low oil movement getting up to the heads.
Duh is offline
post #3 of 8 Old 10-10-2013, 07:40 PM Thread Starter
79chiefs
1988 XJ Cherokee
only one head LOL, no, I have no noise that is why I thought this was strange.
95 E34 540i-DD
79chiefs is offline
post #4 of 8 Old 10-10-2013, 07:49 PM
Duh
Dont see on iphone app which engine you have.
Duh is offline
post #5 of 8 Old 10-10-2013, 07:51 PM Thread Starter
79chiefs
1988 XJ Cherokee
It my 99 WJ I6 4.0 2wd, if that helps.
95 E34 540i-DD
79chiefs is offline
post #6 of 8 Old 10-10-2013, 08:00 PM
-OIIIIIIIO-01
-OIIIIIIIO-01's Avatar
I have the 4.7, but I had the same issue. It was my oil sending unit.
Good luck!
91 YJ 4.0/AX15/231 D30/8.8LSD
35x12.5x16 Nitto Trail Grapplers
Walbro255 MetalCloaks
-OIIIIIIIO-01 is offline
post #7 of 8 Old 10-10-2013, 09:44 PM
grussell
If its not a bad oil pressure switch which is on the side of the block then your camshaft bearings may be worn excessively.
2001 GC Laredo 4.0 4x4 - Black l 2001 GC Laredo 4.0 4x4 - Silver
grussell is offline
post #8 of 8 Old 10-11-2013, 07:38 AM
Jaspah
Hmm, interesting. I believe mine is on its way out since sometimes when driving in the city the potholes and stuff will cause my oil pressure gauge to spike at 80 PSI-- which will fix itself after I restart the engine. I highly suspect that it is just the sensor, since there is no change in how the motor responds to throttle or any changes in sound. Other than that, I'm not sure how much oil pressure differs between vehicles, but I idle at 45 PSI and cruise around 60 PSI.
Jaspah is offline
