Stoopid Hitch! - JeepForum.com
post #1 of 40 Old 06-01-2013, 10:26 AM Thread Starter
TrenchMaker
Wj Stoopid Hitch!
Hi everyone,
I spent all week ordering and returning rear hitch assemblies from local companies. Every hitch I order does not fit over the fuel tank skid plate. Does anyone know of certain part numbers that will work for sure?
TrenchMaker is offline
post #2 of 40 Old 06-01-2013, 10:33 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
8220 6837 from MOPAR
~James
ezflip is offline
post #3 of 40 Old 06-01-2013, 11:12 AM Thread Starter
TrenchMaker
The factory version is the only one that works?
post #4 of 40 Old 06-01-2013, 11:20 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Its the only one that looks right and it is guaranteed to work.
They are also really cheap from junkyard.
~James
ezflip is offline
post #5 of 40 Old 06-01-2013, 12:02 PM Thread Starter
TrenchMaker
Gotchya ok parts hunting this week.
post #6 of 40 Old 06-01-2013, 06:58 PM
Terminal
I'm about to go hitch hunting at the junkyard, too. Can anyone tell me how to get the wiring harness out as well in advance because I have no idea what to look for when I get there to rip it out.
Terminal is offline
post #7 of 40 Old 06-01-2013, 07:29 PM
cpratt247
1. Remove the left side paneling in the trunk.
2. Look for a black/gray foam bag the wiring harness plugs into the pigtail & unclip it.
3. Left rear corner floor board lift the carpet and you'll see the hitch harness running thru a rubber grommet
4.go underneath the WJ and unclip the harness from the hitch...
5. Pull the harness up thru the floor board from outside.
Installation into you WJ is just the reverse.
cpratt247 is offline
post #8 of 40 Old 06-01-2013, 08:12 PM
cykaaro
I found it easier to unplug, and pull the grommet and wiring down thru the floor, and left it attached to the hitch. Attached the hitch, then pulled the wire through the floor, and attached to the main harness and put the grommet into place.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #9 of 40 Old 06-01-2013, 11:45 PM
Terminal
Thanks for the info.
Terminal is offline
post #10 of 40 Old 06-02-2013, 08:10 AM
fast540
If either of ya live in NorCal hit me up I've got a hitch and bumper cover just sitting
fast540 is offline
post #11 of 40 Old 06-03-2013, 08:16 PM Thread Starter
TrenchMaker
Too bad I am up in NorOnt.
post #12 of 40 Old 06-07-2013, 02:41 PM
Merc1973
Go to a junk yard and get the MOPAR factory hitch.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #13 of 40 Old 06-07-2013, 10:46 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
I have a factory hitch on my '04 that I am parting out. Make offer. TrenchMaker, how far are you from Detroit?
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #14 of 40 Old 06-08-2013, 07:37 PM
ace4usmc
When you pull the hitch make sure to grab the factory bezel, when I pulled mine off the donor WJ, I found that the plastic studs that attach the bezel to the bumper were melted to hold it in place instead of using screws or bolts. I ended up having to pry it off which snapped most of the plastic studs off leaving nothing to attach it to my bumper. What I ended up doing, was drilling through the bezel where each stud was with a drill bit the same diameter as the plastic studs. Then using plastic rivets, similar to, but a little smaller (Marson PN# 48106) than the ones used in the wheel well to connect it to the bumper. In my opinion it looks like it could have come from the factory that way.
There is also a lot of good info for installing the hitch on wjjeeps.com
http://www.wjjeeps.com/trailer.htm#DIAGRAMS
and info on the plastic rivets
http://www.wjjeeps.com/grilles/grillesrem.htm#RIVETSET
ace4usmc is offline
post #15 of 40 Old 06-10-2013, 06:44 AM
fastrr
I have been looking at the junk yard to. I know now that if I don't get to pull it myself, I better clarify and re-clarify that I want a factory hitch and not just any hitch. The first time, I was unsure of the knowledge of the guy pulling it. I asked to make sure it was the right one. The guy had the bumper completely off and was getting ready to start unbolting the hitch. I stopped him before he got any farther.
fastrr is offline
