Quantcast Stocker Reliability Thread - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Stocker Reliability Thread
Old 12-24-2008, 11:15 AM   #1
MarxZies
Hello everyone, I thought this might be an interesting thread idea. If you have a stock Jeep just drop your 2 cents!
How well has your Jeep done while being stock in terms of reliability?
2001 WJ 4.0 Inline 6: 83,000 miles, only the battery and tires have been replaced. The back liftgate no longer works (key word "properly") and the drivers side door key broke which is fixed due to cold weather.
MarxZies is offline   Reply With Quote
Old 12-02-2009, 02:25 PM   #2
Chiefs50
I have a 1997 ZJ, 4.0 L with over 123,000 miles. Tires, battery, and muffler have been replaced. I had to replace the lifters (cheap and easy diy job) on the tailgate as they no longer worked in cold weather. I also recently had to replace the tie rod ends and install a new radiator. Other than that just the routine maintenance.
Mike
97 ZJ, 4.0 L, Reese Class III/IV Receiver hitch. Dark Rosewood Pearl
Chiefs50 is offline   Reply With Quote
Old 12-02-2009, 02:34 PM   #3
JrMechanic
Transfer Case Guru
JrMechanic's Avatar
1993 ZJ, 4.0/42RE. 161,000 miles. At 130,000 the transmission was rebuilt, and went out again at 155,000. I've replaced the transmission, torque converter, transfer case (249->231), resealed the engine, water pump, idler pulley, radiator, steering gear box, steering parts and ball joints, front and rear axles (rear axle blew up, swapped to a set with 3.73's), shocks, brakes, rear brake lines, starter, battery, TPS, IAC, CTS, and quite a few other things.
Overall I have no complaints, it's been pretty good for me. I knew what I was getting into when I bought it.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
http://www.jeepforum.com/forum/f13/np249-np231-np242-swap-information-updated-685644/
JrMechanic is offline   Reply With Quote
Old 12-03-2009, 01:15 AM   #4
CherokeeGT
today i bought a 94 zj with a 5.2 it has 480000 k's it leaks but otherwise drives great and runs awesome (i wouldnt have bought it if it didnt run great)
way i see it too is a got a hell of a deal because of the mileage
CherokeeGT is offline   Reply With Quote
Old 12-03-2009, 07:06 AM   #5
zachreynolds
I own a 1997 ZJ Limited. It has 178,000 miles, It has been in 3 accidents. I have had to rebuild the motor (5.2, spun main #2, cracked the block, new block, pistons, crank, cam, 3 angle valve job.), Rebuilt the rear axle (D44a, bearings, 1 axle), Replaced all control arms, replaced the 249 --> 242, Replaced the fuel pump due to obnoxious check valve leaking. The PO Rebuilt the Trans, had oil pump issues (i believe the source for my spun main), replaced Water pump. Overall its been a beast, I've only been left stranded once (when the main spun). I would drive it anywhere, (with my tools in the back of course ) I plan to drive it well past 250,000 with some transmission work and swapping in an 8.8 for the rear axle.
zachreynolds is offline   Reply With Quote
Old 02-15-2010, 12:13 PM   #6
derk69201
1998 ZJ I6 4.0 with 242 bought it july of 2008 with around 198,000 miles :/ (kinda scary) but i have never had any problems with it haven't replaced anything and It has 210,000 miles on it now lol
derk69201 is offline   Reply With Quote
Old 03-10-2010, 04:16 AM   #7
95-ZJ-31
1995 ZJ limited 4.0 257,000 miles runs like a top!
95-ZJ-31 is offline   Reply With Quote
Old 03-10-2010, 05:17 AM   #8
Rickyb
1995 ZJ Limited 5.2 152k
Has had:
Water Pump
Battery
Plugs/wires
Tires
Rebuilt trans
Tensioner Pulley
Idler Pulley
Drive Belt
after market trans cooler
Needs:
rear d44a rebuilt (mostly new bearings)
driver side cv axle
Rickyb is offline   Reply With Quote
Old 03-10-2010, 09:22 AM   #9
LordHobbit
Captain Awesome
LordHobbit's Avatar
'92 4.0l 42re 183k
Just replaced the water pump, checked all the pulleys at that time and found the idler pully I haven't replaced yet was a little loose. May have been the moaning that I was hearing, so I replaced that idler pully too.
anyway, waterpump
idler pulley (2)
valve cover gasket
routine maintenance
fan clutch
radiator
front axle shaft u-joints - then replaced an axle shaft with a cv axle shaft due to warping the tone ring
bought it at 151k seven years ago. Don't know anything that happened prior.
93 ZJ 188k 4.0l, IRO 5.5" springs, hpd30 and 8.8 in the shed, waiting on clayton long arms, 4.88 gears, locker ...
If at first you don't succeed, use more speed.
Originally Posted by RhinofiedZJ View Post
Famous last words, "If you had a locker you would of made it"....:D
LordHobbit is offline   Reply With Quote
Old 03-10-2010, 09:37 AM   #10
FentonWJ
'04 Grand Cherokee SE 4.7 w/ 105,000 miles
2 water pumps
2 thermostats
2 fuel pumps
1 starter
1 battery
1 belt tensioner
1 pair of heads (warped) and head gaskets
1 set of timing chains (cracked guides)
1 set of spark plugs
AND....
1 annoying rattle from the rear. I think it's a shock...factory units that I will replace soon.
When the heads warped I was all but ready to give up on it. Now that I have it back and it runs like a top I LOVE it again.
Sincerely,
Another bi-polar Jeep owner
FentonWJ is offline   Reply With Quote
Old 03-10-2010, 10:32 AM   #11
soul_Less
1994 ZJ
ive got a 94 ZJ have about 263000km or 161000 miles on it. Other then a couple leaks, trashed axle CV shafts, and replacing the water pump, and battery; it runs great still
83000 miles, your still in the break-in period
I'm that asian guy who doesn't drive a Honda Civic.
soul_Less is offline   Reply With Quote
Old 03-25-2010, 07:58 PM   #12
99JGCWJ
99JGCWJ's Avatar
99 WJ Laredo, 77,981 miles. So far I've changed the battery, fan relay sensor, in dash speakers, driver side window mount (my own fault though ), joints, shocks, CPS and now only one hinge on my back window opens. Anybody want to take a bet on what will go next?
SIX IN A ROW MAKES IT GO!!!
99JGCWJ is online now   Reply With Quote
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
