Stock CD player wont eject - JeepForum.com
post #1 of 17 Old 08-13-2012, 12:50 PM Thread Starter
kermit4161
Am on the road and tried a search, but couldnt locate a solution... I have a standard CD/radio ( no changer) and can play a cd. But when I try to eject it, it wont. If I hit the eject, it switches to radio. The mode button will bring it back to the cd...but ejecting goes to radio again.
Is there a way to get it to eject? I have the first cd of an audio book in it...would like to get a new disc in before I get to my destination .
Thanks!
kermit4161 is offline
post #2 of 17 Old 08-13-2012, 01:25 PM
the88thpianoman
2003 WJ
Sounds like the headunit bit the dust. I don't think there is any way to get it to eject short of taking out the headunit and disassembling it to get your CD back. Time to pick up a craigslist/junkyard replacement, or upgrade to aftermarket.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #3 of 17 Old 08-13-2012, 01:31 PM
Jrboarder27
Check to see if there is a very small hole some were that you can stick a paper clip in to. they used to make cd drives like that
Jrboarder27 is offline
post #4 of 17 Old 08-13-2012, 01:31 PM Thread Starter
kermit4161
Ack.. thats what I was afraid of... Too bad. Everything else works great (even plays cds fine). I was going to upgrade sooner or later. I guess it will be sooner.
I might have to extend the audio book I checked out from the library.
post #5 of 17 Old 08-13-2012, 01:35 PM Thread Starter
kermit4161
BTW... It doesnt have a hole to force an eject (unfortunately). It is an RBK unit too.
post #6 of 17 Old 08-13-2012, 01:36 PM
ChrisHager
Administrator
ChrisHager's Avatar
Same thing happened to my stock CD player. I ended up installing a new aftermarket one...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #7 of 17 Old 08-13-2012, 01:38 PM
rcwj04
before I upgraded, mine did that to, all I had to do was let it sit for a while like an hour or so and then try again and the cd would come out
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #8 of 17 Old 08-13-2012, 01:48 PM
the88thpianoman
2003 WJ
That only exists on tray loading drives, not slot loading. Good thinking, though.
That's hopeful.
post #9 of 17 Old 08-13-2012, 04:21 PM
bradywgn71
bradywgn71's Avatar
Mine has stuck a few times. I used the old method of "If it doesn't work, Hit it". I pushed the eject button and then hit the top of the dash with my fist a few times right above the radio. It rattled the disc free. Sometimes, it takes a few tries. I don't use the in-dash player anymore.
bradywgn71 is offline
post #10 of 17 Old 08-13-2012, 07:23 PM
Jrboarder27
That truthfully makes my idea sound stupid
post #11 of 17 Old 08-13-2012, 07:50 PM
victorito
actually this is the best method you can use to get your cd back from the stock unit, "been there done that", hehe!
victorito is offline
post #12 of 17 Old 08-13-2012, 07:55 PM
cde02ltd
This has happened to me too...I just hold the eject button until it ejects.
cde02ltd is offline
post #13 of 17 Old 08-13-2012, 08:59 PM Thread Starter
kermit4161
I will give the 'Hit it' method a shot on my way home. I tried it several times during the drive down. No response to the eject button. Time to beat it into submission (lol)!
post #14 of 17 Old 08-13-2012, 09:21 PM
leadsled jeep
This happened to me on a church burned CD. They had a paper sticker on the disk which made it slightly too thick to eject. Mine eventually came out a little where I could pull the rest with a good set of tweezers.
I look a lot more carefully now on what disks I insert there. Mt back player doesn't work at all so I pulled it and use that area for a nice first aid kit.
Chris
'02 Overland 190k+ miles. 2.5" lift w/springs. All Control Arms upgraded, dual Addco sways.
leadsled jeep is offline
post #15 of 17 Old 08-15-2012, 05:06 PM Thread Starter
kermit4161
Hey all... I tried the 'beat the dashboard' method first thing this morning and it worked!! Then of course, I got cocky and put in the 2nd audio book for my return trip back thinking I could do it all again come next disc change... WRONG ... it started to skip around on the disc randomly, and went back to its old behavior of not ejecting. I tried thumping on the dash, but I think that might only work after its been sitting for a time. So I'll give it another whack in the a.m. on the way into work. A new CD player is in the works as soon as I'm not too tired to do some shopping.
Thanks for all the suggestions!
