Still havent got my Jeep back!:( - JeepForum.com
post #1 of 9 Old 11-01-2011, 08:36 PM Thread Starter
Jeepgcl9947
My 4.7 v8 103000 miles crapped out on me last week. 2 dead cylinders an threw a code for cam timing. What causes it! I've done a lot of research not many answers I'm just scared the engine will need rebuilt. Which I don't have the money for especially on a 4.7 motor so what other motors could you cram in there that are cheaper besides a 4.0 i6 trans and all if needed. Hoping for the best still but we will see!
Jeepgcl9947 is offline
post #2 of 9 Old 11-01-2011, 08:42 PM
shockracer
I6 or the 4.7 v8 would be about the only ones for you. Have they said what broke?
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #3 of 9 Old 11-01-2011, 08:44 PM Thread Starter
Jeepgcl9947
No it's a friends shop an hes pulling the front off Tomorow to see. I just don't understand what makes it do that all of a sudden. It was running fine then just started shaking and crapped out! No loss I oil pressure tho so that can be a good thing.
post #4 of 9 Old 11-01-2011, 08:49 PM
sikrsix
If 2 cylinders have no compression you are in it for a rebuild.
sikrsix is offline
post #5 of 9 Old 11-01-2011, 08:53 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Think I suggested in your other thread, pull the valve covers and see the valves. If the valves are shot, then no need to start pulling the front cover is there?
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #6 of 9 Old 11-01-2011, 09:48 PM Thread Starter
Jeepgcl9947
I would but I don't have it right now he probably will do it. See I thought it was bad gas or a stuck fuel injector because I just filled up and got like 100 feet from gas station and it clunked out.
post #7 of 9 Old 11-02-2011, 02:39 AM
sanddrag
If it was fine then all of a sudden not, to me that sounds more like sensors or electrical. What exactly is "dead" in your cylinders?
sanddrag is offline
post #8 of 9 Old 11-02-2011, 08:16 PM Thread Starter
Jeepgcl9947
There not firing. The gas is just dumping in
post #9 of 9 Old 11-02-2011, 08:26 PM
shockracer
Should do a compression test, and spark test.
