still have a little bump steer - JeepForum.com
post #1 of 6 Old 12-16-2010, 09:19 PM Thread Starter
travisbanshee67
ok so after lifting my jeep I was on the highway going about 65 and got death wobble really bad. so i ordered a rough country dual steering stabilizer, well that took care of the death wobble but it still has bump steer, steering wheel shakes a little when i hit a bump. so i ordered a drop pitman arm from rugged ridge, went to install it and realized it wont work with the dual steering stabilizer, do you guys have any other suggestions what i can do to get rid of this annoying bump steer?
travisbanshee67 is offline
post #2 of 6 Old 12-16-2010, 10:17 PM
narnwv
narnwv's Avatar
is it bump steer or death wobble?
steering stabilizers will not FIX death wobble. They'll just mask it. Check your tie rod ends, sway bar links+mounts.
~Aaron
narnwv is offline
post #3 of 6 Old 12-16-2010, 10:41 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Also control arm bushings. The axle is located by the track bar and the control arms. Get all the bushings and rod ends in good condition and you will probably be fine. The dual-SS system is really only a good idea if you have LARGE tires as the stock single camper can't damp that much energy on its own. Otherwise you are just trying to cover up symptoms and not actually fixing them.
~Richard
billzcat1 is offline
post #4 of 6 Old 12-16-2010, 10:44 PM
billzcat1
2003 WJ
Oh also.... did your lift come with a drop track bar bracket? You don't want that. You want your drag link and your track bar to be parallel to avoid bump steer. Otherwise your axle has two different pivot points as as it moves up, the steering twists. Run it with stock track bar bracket and an adjustable track bar.
~Richard
post #5 of 6 Old 12-17-2010, 06:38 AM Thread Starter
travisbanshee67
I have an adjustable trac bar and the tie rods are all seem to be tight . Control arm bushing are in good shape not torn , I have adjustable arms on the lower, I was thinking it was the drag link angle is to much, is there anything else I can do to fix the angle because the drop pitman arm won't fit because it hits the drivers side stabilizer shock
post #6 of 6 Old 12-17-2010, 07:19 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Ill put money on your track bar not being torqued tight enough. Get a friend to turn the steering wheel back and forth as you are under it watching every part of the steering. Then fix whats loose.
~James
ezflip is offline
bump stops gc3381 WJ Grand Cherokee Forum 4 12-20-2010 12:05 PM
CLUNK n bump on the Highway torx WJ Grand Cherokee Forum 14 11-01-2010 04:07 PM
WJ bump in 1st and 2nd Gear RootJ WJ Grand Cherokee Forum 4 07-18-2010 07:20 PM
WJ front bump stop ideas???? Atlas92 WJ Grand Cherokee Forum 8 06-23-2010 12:23 PM
Come to a stop...then a bump feel? summett WJ Grand Cherokee Forum 4 05-27-2003 07:19 PM
