Sticking caliper causing a shimmy?? - Page 2 - JeepForum.com
post #16 of 41 Old 10-30-2013, 07:38 PM
2ndhandWJman
I've been having the same exactly symptoms. Yesterday, I stopped by a buddies body shop, when I got out I could smell break dust/ hot brakes. My hand found the hot one real quick- the drivers side front. I dragged out a floor jack and lifted up that corner, the wheel turned freely. I scratched my head for a second then grabbed the wheel and tried to wiggle it in all directions, thinking maybe it was a bad wheel bearing.
After this test found nothing wrong, my buddy suggested stepping on the brakes, then try turning the tire. After I let go of the brake pedal, he tried to turn the tire and it wouldn't budge. After about 5 minutes it started to turn a bit more freely. I'm betting on a sticky caliper, nothing else makes any sense.
Moral to this long response- jack up the suspected corner, step on your brake pedal then try to turn the tire.
2ndhandWJman is offline
post #17 of 41 Old 10-31-2013, 05:55 AM Thread Starter
Jaketit
Well it seems to be sticking when it wants too. I just took the kids to school and no wheels were hot again. So would a warped rotor cause my shimmy??
Jaketit is offline
post #18 of 41 Old 11-01-2013, 04:13 PM
2ndhandWJman
It could cause a shimmy, but usually with warped rotors you get a pulsating brake pedal when you step on the brakes. If it helps you- I changed my sticky caliper yesterday along with both rotors and a fresh set of pads. My problem is 100% gone. One of the pistons in the caliper was so frozen, I couldn't collapse it using a big C clamp.
post #19 of 41 Old 11-01-2013, 07:25 PM Thread Starter
Jaketit
Little update on what's going on. I tightened the control arms really good and the shimmy moved up 10mph. Somebody tell me what that was. Anyways I just rotated the rears to the front to see if its a bad tire or something. I'm not really getting the brake shimmy at slow speeds so it must not be warped rotor. Ill update tommorow after the drive to work. Thanks guys.
Jaketit is offline
post #20 of 41 Old 11-01-2013, 07:53 PM
brouwmat
if your rotors are warped, it'll shimmy your hand off :-) Once drove our SHO 5 hours down the interstate with that... not fun.
mine would start out slow at first, build, and turn into a bad vibration after I got my speed up. You might want to have those rotors turned. That would tell you for sure.
brouwmat is offline
post #21 of 41 Old 11-01-2013, 08:33 PM
zjcherokeebob
I had a rusted caliper slider. Felt like a warped rotor but brakes had just been replaced.
zjcherokeebob is offline
post #22 of 41 Old 11-04-2013, 03:14 PM Thread Starter
Jaketit
So just a little update on how it's been riding. Saturday night I rotated the rears to the front and it got even better as far as wobble. So it's not the brakes. I did however rotate my one bad tire to the front so now there is a vibration back in the front end again. So it's either wobble or vibration. Until I get sick of these not really good road tires. Kevlar MTRs don't make a daily driver tire IMO.
Jaketit is offline
post #23 of 41 Old 11-04-2013, 04:07 PM
ChrisHager
Administrator
ChrisHager's Avatar
If the vibration changes when you move tires around, you've found your culprit!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #24 of 41 Old 11-04-2013, 04:13 PM Thread Starter
Jaketit
Oh for sure. But I knew about the vibes from the rear tire but it seems like I now have a front tire that vibrates bad and a rear that wobbles.
Jaketit is offline
post #25 of 41 Old 11-05-2013, 05:23 PM Thread Starter
Jaketit
http://youtu.be/sKVMz7dkwmE
Here is what I've come up with lately. Pittman arm or gearbox is loose. Seems like the gearbox. And the second clunk is from my trackbar. Any thoughts on the gearbox Causing some wobble??
Jaketit is offline
post #26 of 41 Old 11-06-2013, 06:39 AM
brouwmat
Video Link: http://youtu.be/sKVMz7dkwmE
If the box is loose and doesn't hold firm I could see how it would set it off.
brouwmat is offline
post #27 of 41 Old 11-06-2013, 05:26 PM Thread Starter
Jaketit
So I'm taking my heim joint off the RC trackbar tommorow and bringing it down to a local 4x4 shop to get a better one. I noticed a lot of play in that joint yesterday. Also was wondering if the angles of the steering arm and trackbar are correct looking. I thought they were supposed to be at the same angle. It's been like this for a year and a half now. I'm the idiot that has a track bar drop bracket and a drop pitman arm.
Jaketit is offline
post #28 of 41 Old 11-06-2013, 05:29 PM Thread Starter
Jaketit
By the way if you look closely at the exhaust by the O2 sensor you can see my waterline from when I got stuck a few months ago. Doh!!
Jaketit is offline
post #29 of 41 Old 11-07-2013, 10:49 AM Thread Starter
Jaketit
Ok, so today I went and got my RC trackbar heim joint replaced with a beefier one. What a difference. Now my track bar is nice and solid. One down and who knows how many more things to go. Next will be steering box. The shimmy is still a bit there at 50 mph but seems like I'm gaining on it. It's definitely not the rotors.
Jaketit is offline
post #30 of 41 Old 11-08-2013, 01:39 PM
2ndhandWJman
At least you are being methodical about finding the issue(s) instead of replacing everything in sight. In regards to the track bar angle, it looks a bit off. The drag link and track bar should both have the same angle on them. When they have different angles, it will induce bump steer and sometimes the dreaded DW.
I fought for so long with similar issues on a Dodge Ram with the factory Off Road package, I swore I'd never own another chyrsler product again. Here I am, 5 years later with a Jerp that uses the same darn suspension design.....
