Sticking caliper causing a shimmy?? - JeepForum.com
post #1 of 41 Old 10-30-2013, 08:27 AM Thread Starter
Jaketit
Ok so I've had some wobble issues these past 2 weeks which I thought I pretty much tracked down this week but NOPE. Well the death wobble has been cured but after changing both front upper and lower ca bushings and adding a new stabilizer everything was smooth as silk for 2 days and now I'm getting
Jaketit is offline
post #2 of 41 Old 10-30-2013, 08:31 AM Thread Starter
Jaketit
A shimmy at 40-50 mph. I took it in last night to get the tires rebalanced and two were off by 1.00 oz on one side. Thinking that was my problem I headed home only to find the shimmy was still there. I'm starting to think I'm getting this wobble after hitting my brakes hard, maybe I have a caliper sticking occasionally. Anybody ever heard of this. And if so how should I check for it.
Jaketit is offline
post #3 of 41 Old 10-30-2013, 08:32 AM
ChrisHager
Administrator
ChrisHager's Avatar
When braking, do you have a shimmy (as in a warped rotor)? If your rotor is good, an occasional dragging brake shouldn't cause a shimmy, though a dragging brake isn't necessarily a good thing!
Is the wobble random or rotational?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #4 of 41 Old 10-30-2013, 08:44 AM Thread Starter
Jaketit
It's both, some times I feel like a warped rotor wobble at slow speeds and sometimes not. And also random shimmy at 45.
Jaketit is offline
post #5 of 41 Old 10-30-2013, 08:50 AM
ChrisHager
Administrator
ChrisHager's Avatar
Stupid question but your lug nuts are tight, right?
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6 of 41 Old 10-30-2013, 08:56 AM Thread Starter
Jaketit
I watched the tech at tire kingdom torque em down. Hmm maybe a wheel spacer?
Jaketit is offline
post #7 of 41 Old 10-30-2013, 09:03 AM
ChrisHager
Administrator
ChrisHager's Avatar
If you have wheel spacers, check them. This shimmy could be caused by many things but checking a safety item should be the top priority if there is even the slightest doubt!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #8 of 41 Old 10-30-2013, 09:07 AM Thread Starter
Jaketit
I hear you. I'm gonna get out the old jack and check everything out. I'm just sick of throwing money at this problem for just a few days of gratification, then back to riding like butt.
Jaketit is offline
post #9 of 41 Old 10-30-2013, 09:32 AM
brianestep
Since you've already replaced the bushings of both U and L control arms (nice move!), next up would be hubs and ball joints. Jack up one wheel/tire at a time and grab at 3/9oclock and wiggle. Then grab at 12/6oclock and wiggle. If there is play, watch where it is sourced from (either ball joint or hub).
Depending on who you ask, wheel spacers wear out the ball joints mildly faster.
-Brian- 2000 WJ Four liter, 4" RC springs; Bilstein 5100s; JKS trackbar w/KOR bushings; Stillen rotors; KOR (RC) 1.5" wheel spacers; 265/75/16 Treadwright Guard Dogs; Rusty AirTube, Amsoil Cone; Thule M.O.A.B.; Bumper delete; rear seat disco
brianestep is offline
post #10 of 41 Old 10-30-2013, 09:33 AM
mattmc74
2009 JK Wrangler
I was having some shimmy as well. All of the front end parts were replaced and all was good. Had a bit of shimmy when going over 45mph, it was driving me nuts trying to find out what was causing it. 2 days later my passenger side front caliper stuck and was smoking really bad! Replaced both front calipers plus pads,rotors, and the shimmy is gone. Thinking maybe when it got hot from the caliper being stuck and getting too hot caused too much drag on the passenger side which was causing my shimmy.
mattmc74 is offline
post #11 of 41 Old 10-30-2013, 09:46 AM
BlueJc
its easy to check for sticking brakes as your wheel will get hot. Check all four wheels for heat after a run out, the hot one will have the sticking brake. You should also see a drop in MPG if you have a dragging brake.
2002 2.7 CRD Jeep Grand Cherokee. 205 BHP, 500 NM of torque, Bluespark Automotive Pro Tuning.
BlueJc is offline
post #12 of 41 Old 10-30-2013, 10:17 AM
bentbolt
I had this with brand new rotors and it was warped .006". Turned them down to both be turn and it cured it.
bentbolt is offline
post #13 of 41 Old 10-30-2013, 11:03 AM Thread Starter
Jaketit
Well no hot wheels. I just picked up the kids in it and again accelerated to 50 and took my foot off the gas and on deceleration it feels like the verge of DW. i also went over some bad bumps and nothing at all. Maybe it just sticks when it wants too. I did notice ALOT more brake dust on the passenger rear wheel while I had it in the air. I also checked for play in the wheels checking ball joints and hubs but they seem solid. Has me stumped again. Guess its time to take out the old wallet again. Sheesh
Jaketit is offline
post #14 of 41 Old 10-30-2013, 04:36 PM Thread Starter
Jaketit
Ok well. After a day of checking stuff out and test driving I did find a couple problems. One being I but the long bushing crush sleeve in the short side of the control arm. Duh!!! I knew something wasn't right while installing. RC arms by the way. That didn't really do much as far as the shake goes but I did remember to check my wheels for excessive heat and YAHTZEE my front driver side wheel was a lot hotter than the rest. Like I said in my previous post the feeling comes and goes sparaticly. So maybe ill get a new caliper tommorow and I guess I'm going to need a new rotor also.
Jaketit is offline
post #15 of 41 Old 10-30-2013, 05:03 PM Thread Starter
Jaketit
And I just did pads and rotors all around about a year ago. 02 akebono.
Jaketit is offline
