Steering Wheel Noise - WJ Overland - JeepForum.com
post #1 of 15 Old 03-23-2010, 08:23 PM Thread Starter
bb1968
I'm have a rubbing noise coming from the top of the steering column somewhere around the steering wheel. What's odd is that it only makes this sound when making a left turn and it's more pronounced when the car is cold.
I'd appreciate it if anyone has some insight as to what the noise is or where it could be coming from. I called the service dept at the dealer and he thinks it could be the clockspring but it seems like it's coming from a little lower.
bb1968 is offline
post #2 of 15 Old 03-24-2010, 01:49 AM
JesseOR
My ZJ does the same thing but when I turn to the right......I thought it may be the pump but it can't be heard outside the jeep.
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
post #3 of 15 Old 06-04-2010, 07:26 PM
dextux
I finally took my '04 Limited into the dealer for the exact same thing, a rubbing noise coming when turning left. He couldn't find anything wrong and he said the steering column is starting to go bad. $1200 repair.
dextux is offline
post #4 of 15 Old 06-04-2010, 09:46 PM
BSweet
Mine makes the same noise. Only when turning left too. I am goin to try to lube the intermediate shaft where it goes through the firewall and see if that helps.
'98 ZJ 5.9 Limited/1998 ZJ Laredo
'06 Wrangler Rubicon
'15 Cherokee Trailhawk
'62 Willys CJ5
BSweet is offline
post #5 of 15 Old 06-04-2010, 10:09 PM
straty1987
my and my uncles WJ make a noise, i think its common to a point
straty1987 is offline
post #6 of 15 Old 06-05-2010, 08:00 AM
dbozman
2010 WK
My '99 does it too. Worse when cold. Sounds more like a plastic-on-plastic cracking sound. Sorta like plastic dash parts rubbing together. I try to ignore it.
dbozman is offline
post #7 of 15 Old 06-15-2010, 02:00 PM
sprice37
There are TSB's for this issue
http://www.wjjeeps.com/tsb/tsb_wj_190600.pdf
http://www.wjjeeps.com/tsb/tsb_wj_1900301a.pdf
I am starting the repair on mine with the cheaper of the two fixes. Will let know how it goes.
sprice37 is offline
post #8 of 15 Old 06-16-2010, 08:32 PM
sprice37
Replaced the hoses today and the noise went away for the most part. Happens rarely now. The powersteering fluid was very dirty so I wonder if that had something to do with it. might try a couple fliud changes and see what happens.
sprice37 is offline
post #9 of 15 Old 06-16-2010, 09:36 PM
PCJona
happens to mine going in both directions.
dealer said it was a 600 dollar repair so... HA
doesnt really bother me tho.
i have a radio, and i use it
PCJona is offline
post #10 of 15 Old 06-16-2010, 09:42 PM
sprice37
DIY
50 bucks for hoses and fluid,140 for the steering gear. less then 200 and about 2 hours on the high side.
sprice37 is offline
post #11 of 15 Old 06-16-2010, 10:14 PM
WJChris
WJChris's Avatar
you guys realize that the clockspring is a wound up ribbon cable in the column?
Mine makes that noise, and i KNOW for sure its the clockspring cable, because it never made that noise until I changed it!!!!
WJChris is offline
post #12 of 15 Old 06-16-2010, 10:31 PM
sprice37
I completely dissconnected the steering column from the gear box and turnes the gear box with a wrench. Made the noise that the TSB's refer to. Defintely not the column on mine, although I thought it was at first.
sprice37 is offline
post #13 of 15 Old 06-22-2010, 04:39 PM
sprice37
Well i just completed the project and replaced the steering gear. To my suprise the noise is completely gone. Looks like the TSB's were right. Thought you might like to know. With the clockspring issue maybe you got a bad one.
sprice37 is offline
post #14 of 15 Old 06-22-2010, 04:48 PM
PCJona
so it was the steering gear?
how much does that cost
PCJona is offline
post #15 of 15 Old 06-22-2010, 04:54 PM
sprice37
I replaced the powersteering hoses and gearbox, bought a steering arm puller and a 33mm socket, and 2 quarts power steering fluid.
Pwr steer gear 140.00
steering hoses 50.00
steering arm puller 15.00
33mm socket 10.00
2 qt pwr steer fluid 10.00
Total 225.00 lifetime warranty on the gear box and hoses
I did the work my self in about 2 hours taking my time. Really a very easy change out.
sprice37 is offline
clockspring
4.7 HO Overland WJ - Steering Noise ?? reading1800 ZJ Grand Cherokee Forum 3 01-25-2010 02:17 PM
Overland steering wheel in a 2001 Limited markywmson ZJ Grand Cherokee Forum 1 11-29-2009 12:46 AM
adding overland steering wheel to limited. allenc ZJ Grand Cherokee Forum 8 10-27-2007 12:15 PM
Overland steering wheel? SouthernboyWJ ZJ Grand Cherokee Forum 2 01-11-2007 08:00 PM
2004 overland steering wheel in 2001 limited? NoLimitsLimited ZJ Grand Cherokee Forum 3 12-27-2006 02:28 PM
