Steering Stablilizer Opinions - JeepForum.com
post #1 of 23 Old 04-08-2014, 10:50 AM Thread Starter
Cavadus
Who makes a good one? Seems like every company that makes a lift kit makes one.
I've also heard that the dual stabilizer setups are a bad idea. Is that true? And if so, why?
Thanks
Cavadus is offline
post #2 of 23 Old 04-08-2014, 11:15 AM
Super6XJ
i am looking for one aswell, leaning towards RC Steering Stabilizer, from what i have heard about duals are
if you need 2, then check your linkage make sure nothing is loose or worn out, i just need to replace the OEM one
Your Welcome
Super6XJ is offline
post #3 of 23 Old 04-08-2014, 11:18 AM
Double E
Double E's Avatar
I got a unit from Iron Rock Offroad. Added the protective bellows too. Been good for 3 years. Beefier looking than the OEM unit but probably the same performance.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #4 of 23 Old 04-08-2014, 02:18 PM
veiri86
2003 WJ
Double steering stabilizer is not needed, besides the fact that it will increase the load on your power steering pump. So I suggest to get only one SS. For brands, am using MOOG Trail Boss from Kolak and it works fine. Another options can be Zone Offroad or IRO
Sent from ME
R.I.P ratmonkey
Build thread:
01' 4.7 Limited WJ 5" lifted, Rubicon Express 4.5" coil springs with IRO critical path setup and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), JKS HD tie rod (MOOG problem solver Ends), JKS HD drag link (Moog Probel solver Ends), 4.56 Yukon ring and pinion, Moog HD SSD107 Steering Stabilizer, IRO Front drive shaft conversion, Stillen slotted rotors all around with Stillen brake pads, IRO adjustable A-Arm, 3" all the way Kolak Exhaust with High flow Magnaflow Cat. Converter and Flowmaster Super 50 Muffler, 285/70R17 AT Kumho (33") on 17" BlackWheel rims 909B, K&N Cold air intake, Four nozzles Bosch injectors, and Flashpaq 3780.
03' 4.7 H.O WJ 3" lifted, OME HD with 0.5" Coil spacers and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), Moog Problem solver TRE's, IRO Front drive shaft conversion, IRO adjustable A-Arm, High flow magnaflow mini cats, high flow magnaflow cat, Flowmaster Super 44 muffler, 265/65R17 AT Yokohama on 17" Rays rims, and Flashpaq 3780
veiri86 is offline
post #5 of 23 Old 04-08-2014, 05:44 PM
imaguy3
This one has served me well for the past 3 yrs http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
EvilEagle - "Imaguy3 just made everyone in this thread his *****."
imaguy3 is offline
post #6 of 23 Old 04-08-2014, 06:05 PM
peytonimor7
Can you post a picture of these "protective bellows" you speak of?
l 04 WJ l OME HD+3/4" spacers l Bilstein 5100 l 245/70/17 Firestone M/Ts l IRO A-Arm & CAs F & R l
peytonimor7 is offline
post #7 of 23 Old 04-08-2014, 11:12 PM
bradywgn71
bradywgn71's Avatar
I use this one made by Moog: http://www.amazon.com/Moog-SSD107-St...rds=moog+sd107
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline
post #8 of 23 Old 04-10-2014, 09:37 AM
r1raven
installed the moog trail boss as well and feels good and very beefy compared to stock
r1raven is offline
post #9 of 23 Old 04-10-2014, 04:40 PM
RIJeep01
I read some reviews on Amazon about the bolts that come with the moog steering stabilizers, do they come with the right hardware (too short)? What's the difference between super trail boss and the trail boss?
RIJeep01 is offline
post #10 of 23 Old 04-10-2014, 05:27 PM
bradywgn71
bradywgn71's Avatar
The hardware that came with mine worked fine.
post #11 of 23 Old 04-10-2014, 08:06 PM
peytonimor7
Same here, the bolt is ALMOST short but they provide a nylon lock washer so it's all good.
post #12 of 23 Old 04-10-2014, 10:57 PM
Cebby
I'm running a pair of Kevin's - installed prior to having Claytons (and a correct caster angle). Probably only need one now...
2000 WJ Laredo 4.0 4x4 Taupe Frost - Stroker | Clayton LA w/3" Lift | 33's on JK 17's | Axles next
Cebby is offline
post #13 of 23 Old 04-10-2014, 11:39 PM
Hack
2003 WJ
Mine came with the wrong hardware, but that was a couple years ago. I installed one on another jeep a few weeks ago and it came with the right hardware. I'm guessing they updated the kit since more people seem to say it comes with the right stuff lately.
Hack is offline
post #14 of 23 Old 04-11-2014, 04:01 AM
wtf03WJ
2003 WJ
I also put the Moog trail boss on recently. The bolt for the clamp on the tie rod sleeve was just slightly too short. The nut would only go on one or two threads. This was on the slightly beefier Moog tie rod tube, would probably have been exactly right on the thinner stock tie rod. Quick trip to home depot for a longer bolt and it was all good. Feels much better than the old original steering stabilizer.
wtf03WJ is offline
post #15 of 23 Old 04-11-2014, 03:24 PM
RIJeep01
So if i'm driving a stock height wj I would assume I would just get the regular trail boss not the super trail boss...I don't go off roading too much. I'm starting to get a little wander in my steering and the stabilizer on there is still original.
RIJeep01 is offline
