Is this squeek the ball joint or brakes? - JeepForum.com
post #1 of 1 Old 02-20-2012, 09:16 PM Thread Starter
OTownDaddy
2007 XK Commander
Question Is this squeek the ball joint or brakes?
I'm attaching a video link, but listen - you might have to turn the sound up. Trust me, when you're in the Jeep it's a LOT louder than it sounds on the video. It sounds like it's coming from the left front.
http://www.youtube.com/watch?v=8gS5U...ature=youtu.be
Is this the brakes or a ball joint, or something else? Doesn't do it all the time - seems to be intermittent. Usually within the first 5-7 minutes of driving.
Also, I know I have a bad right side front caliper, as I pull to the left a little braking above 40 mph. Sometimes, when going slow, when I depress the brake, I get the same sounding squeek for 3/4 of a second. Gut tells me it's the brakes, just thought I'd see what the JF braintrust thinks too.
Any ideas?
2007 XK Limited 4x4 | QD-II | 18" wheels (gotta dump these for some 17s) | The rest is stock
OTownDaddy is offline
brakes , jeep , squeek , wj
A arm ball joint AGAIN!!?? roadcrew WJ Grand Cherokee Forum 6 09-08-2011 09:49 PM
Help with ADJ BALL JOINT please XJ57 WJ Grand Cherokee Forum 3 07-09-2011 08:04 PM
TRE or Ball joint brianestep WJ Grand Cherokee Forum 17 04-23-2011 02:24 AM
Tie rod or ball joint? aceshootn WJ Grand Cherokee Forum 0 09-10-2010 05:29 PM
ball joint ? ctwistedpair WJ Grand Cherokee Forum 1 05-06-2010 02:08 AM
