Squeaking KOR bushings - Page 2 - JeepForum.com
post #16 of 21 Old 08-19-2014, 08:31 PM Thread Starter
jetrinka
I wanted to update this thread. I ended up pulling the track bar out completely today and taking both the bushings out. I cleaned the old viperlube out and instead used a silicone based grease made by ACdelco for brakes that is supposedly safe on plastics. Unlike the viperlube that washes off almost instantly with brake cleaner, the ACdelco brake grease just laughs at it which makes me think it will last much longer. So far so good, no more awful creaking sounds.
jetrinka is offline
post #17 of 21 Old 01-22-2016, 03:22 PM
leadsled jeep
Did it continue to hold up? I'd like to here more if so. I am installing KOR bushings and JKS Trackbar tomorrow.
Chris
'02 Overland 190k+ miles. 2.5" lift w/springs. All Control Arms upgraded, dual Addco sways.
leadsled jeep is offline
post #18 of 21 Old 01-22-2016, 09:59 PM
Crzhelm
mine squeaks. i got pissed and replaced bushings then just 2 months squeaks again.. now i just shoot it with wd40 once a month.
i was thinking next time i have it apart im cutting some groves in the bushing to hold the grease better.
Crzhelm is offline
post #19 of 21 Old 01-23-2016, 09:44 AM
Tollmtn
The people that manufacture track bars that use polyurethane bushings should install grease fittings so they can be regularly greased. Grease keeps the bushings from squeaking and makes them last longer. The good news is it only takes a few minutes to drill and tap for grease fittings.
"There's nothing so absurd that if you repeat it often enough, people will believe it." W.J.
Tollmtn is online now
post #20 of 21 Old 01-23-2016, 08:54 PM
leadsled jeep
I dremeled some diagonal slots into my KORs in an attempt to hold more grease. We will see if it helps. If not I'll go with TollMtns idea.
Chris
post #21 of 21 Old 01-24-2016, 12:28 AM
willis36
willis36's Avatar
What's wrong with the rubber bushing that comes with the jks bar?? Completely silent and more than capable of doing its job.
willis36 is offline
