spyder v3's and hid - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > spyder v3's and hid
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS HD TJ Replacement Hinges
Unread 03-08-2013, 07:06 AM   #1
jaybob1807
spyder v3's and hid
Ok guys, I have some spyder v3 projectors with ccfl halo's installed on my jeep. I also have a ddm tuning 55watt 5000k hid kit installed also. I am wondering if these headlights are made for hid kits? One thing that I noticed is that the cutoff point almost has like a purple blue line to it. Is that normal or do I need to swap out the projectors in these headlight housings?
jaybob1807 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 07:33 AM   #2
CantFocus
2003 WJ
They are not designed for HIDs. They are halogen projectors as you can tell by the hot spots they produce.
[B][SIZE="3"]Zombie Outbreak Response Unit #338[/SIZE][/B]
2003 WJ Laredo 4.7 Loaded including Upcountry Package - 2" BB - Rola rack - V3 Black Projectors - 55W 5000k HIDs - Yellow 9005 fogs - JKS Discos.... More to come
CantFocus is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 07:38 AM   #3
Gunrunner23
You would have to retrofit for actual HID projectors. Retrofitsourcd is a good place. Google it. Morimoto mini are easy cheap and great!
Sent from my Motorola Photon using JeepForum
2004 wj limited 4.7
IRO 3in lift with skyjacker hydro
265/75/16 TreadWright Claws
Gunrunner23 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 10:08 AM   #4
ZB_WJ
Yeah mine has that purple line as well, I just don't care.
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 11:30 AM   #5
jaybob1807
Is the installation easy for retrofitting hid's?
Unread 03-08-2013, 12:41 PM   #6
pauler
The headlights in question fit the OEM bulb
Get HIDs that fit the OEM bulb size
they are plug and play. If you want them to last a long time, perhaps invest in a HID wiring harness so the ballasts get consistant voltage and die out prematurely.
01' Silverstone WJ Limited
-Debadged, K&N CAI, Quad taillight mod, Yellowtop Optima, 3000 watt stereo setup, Kolak 3' Catback (flowmaster 70 with magnaflow tip and high flow magnaflow cat) with DMH electric cutout, Overland woodgrain wheel
pauler is offline   Reply With Quote Quick reply to this message
Unread 03-08-2013, 02:17 PM   #7
jaybob1807
I already have a DDM tuning HID kit with the spyder v3 headlight assemblies. What I am curious about is the installation of the Morimoto mini?
Unread 03-08-2013, 08:46 PM   #8
Gunrunner23
Ok well my bad I saw it was from a competing forum so the link was messed with. Anyways google how to do it several sites will come up
2004 wj limited 4.7
