Sporadic steering wheel position - JeepForum.com
post #1 of 12 Old 01-04-2011, 03:19 PM Thread Starter
w0mps
Wj Sporadic steering wheel position
Just noticed this yesterday. What would cause a steering wheel to be misaligned with the wheels? I also had gotten death wobble the other day for the first time (twice in a day). After driving home from work I noticed the steering wheel was misaligned.
- Andrew
w0mps is offline
post #2 of 12 Old 01-04-2011, 03:23 PM
smunns
Do you have the basic RC 4" lift? Are you running the track bar drop bracket? If so, I bet it's loose causing your axle to shift when you hit bumps. It would also cause death wobble. Replace the bracket and stock track bar with a JKS track bar. Also ditch the drop pitman arm if you're running it.
smunns is offline
post #3 of 12 Old 01-04-2011, 03:25 PM Thread Starter
w0mps
Yep looks like I have the stock track bar and a drop bracket. I guess I should try tightening it up, perhaps loctite, until spring when I start upgrading.
- Andrew
w0mps is offline
post #4 of 12 Old 01-04-2011, 03:27 PM
smunns
That should help, but odds are it will keep coming loose. I ditched the drop pitman arm and replaced the track bar drop bracket and stock track bar with a JKS track bar, and it's night and day difference. If you go the JKS route, PM Kolak, he has great prices on them.
smunns is offline
post #5 of 12 Old 01-04-2011, 03:28 PM Thread Starter
w0mps
Sweet! Sounds good. I just noticed you have the same lift as I do. I am considering doing 265/70's with my stock 17" Avila's. What do you think?
- Andrew
w0mps is offline
post #6 of 12 Old 01-04-2011, 03:31 PM
smunns
Check out my build thread. (Link in my sig.) I ran the same combo when I first got my Jeep. I'd recommend at least wheel spacers if you want to run those wheels with 265/70's.
smunns is offline
post #7 of 12 Old 01-04-2011, 03:39 PM Thread Starter
w0mps
I am in the process of reading your build now, pure sexiness. Awesome fab work too.
I've heard bad things about wheel spacers, how they're unsafe, especially while wheelin', so I don't really want to run them. My next choice was to go with new wheels (16x8 with 5" backspacing). Just because it will bring the tire out a little farther, the tire is about $100 cheaper than a 17" and I have a white WJ, so in my opinion, a flat black wheel looks great with the white body.
- Andrew
w0mps is offline
post #8 of 12 Old 01-04-2011, 03:46 PM
smunns
As long as you get a quality spacer, and keep it torqued properly, they are fine. I've run a couple of different sets on a couple of different Jeeps for probably 30k+ miles without any problems. New wheels are the ideal way to go though. I only run spacers because I got a great deal on the JK moabs I run.
smunns is offline
post #9 of 12 Old 01-04-2011, 03:51 PM Thread Starter
w0mps
What do you recommend for a wheel spacer? I've never had to use them... I'd really like to rock the stocker wheels!
- Andrew
w0mps is offline
post #10 of 12 Old 01-04-2011, 04:02 PM
smunns
Spidertrax are probably the best, but I've had good lock with my Rough Country spacers.
smunns is offline
post #11 of 12 Old 01-04-2011, 04:14 PM Thread Starter
w0mps
Cool, thanks for the info man!
- Andrew
w0mps is offline
post #12 of 12 Old 01-04-2011, 04:29 PM Thread Starter
w0mps
Just took a peek at my trackbar and also noticed the P.O. welded the drop bracket to the stock one.
- Andrew
w0mps is offline
Steering Wheel Locked Ronjon17 WJ Grand Cherokee Forum 5 12-29-2014 08:00 PM
Steering wheel a little off... sk8anddsm WJ Grand Cherokee Forum 0 12-26-2010 09:42 PM
Does the Steering Stabilizer have a "Neutral" position? Twospeed WJ Grand Cherokee Forum 1 09-12-2010 09:48 PM
Steering wheel noise Bubba3200 WJ Grand Cherokee Forum 1 08-31-2010 06:51 PM
