Speedometer Problem - JeepForum.com
post #1 of 6 Old 05-20-2013, 06:45 PM Thread Starter
jote8
Wj Speedometer Problem
Hi Friends, I need your help!!
My Jeep (WJ - 2004)
I have a problem with the speedometer.
- start from 40 kph (24.8 mph).
- returns to 0 kph only when I remove the key contact.
- is a normal operation when accelerated, but as a starting point is 40 Kph.
- check both speed sensors in the transmission, disconnect both sensors, but the speedometer starting from 40 Kph !!
- perform the test board and runs correctly,ok.
- the ignition automatically give the marker is located in the 40 Kph
Please your help
Greetings from Chile
jote8 is offline
post #2 of 6 Old 05-20-2013, 06:53 PM
lazyWJ
2006 XK Commander
I can't help you but I love your wine.
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #3 of 6 Old 05-20-2013, 07:01 PM
rm2001wj
rm2001wj's Avatar
Speedometer operation does not use the transmission speed sensors. Instead, the ABS controller uses wheel speed sensor signals to generate a vehicle speed signal. Unfortunately, I have no useful information on why the speedometer does not start at zero like it should.
rm2001wj is offline
post #4 of 6 Old 05-22-2013, 02:52 PM Thread Starter
jote8
Hi rm2001wj, Thanks!
I have an idea about this, a cable may be defective wheel, keep them informed
lazyWJ, of course chile wine is very good, especially in my town (Santa Cruz, Colchagua Valley)
jote8 is offline
post #5 of 6 Old 05-22-2013, 03:00 PM
Schlotzky
2007 XK Commander
Has the cluster been recently taken apart? My first thought was someone took the needle off the speedo and replaced it with the ignition off. The needle should be pressed on at 0 km/h with the ignition in the "on" position.
Schlotzky is offline
post #6 of 6 Old 05-22-2013, 03:45 PM
RIPNBST
How often are you traveling below 25 mph that your speed must be known? It would bug me like crazy but you probably don't really need to fix it either.
Schlotsky I don't think that is it because at 10 mph actual speed his speedo would read ~35 mph if that were the case. It would be constantly off by the margin of ~25 mph. If I read his post correctly the needle is stationary up until ~25 mph and then accurate after that.
EDIT: Just read the OP again, Schlotsky may be right. English as a second language confused me.
RIPNBST is offline
