Speed sensor - JeepForum.com
post #1 of 15 Old 07-06-2012, 04:30 PM Thread Starter
Gunrunner23
Speed sensor
I recently have heard my transmission do some weird things. First when it goes into overdrive it sounds like it readjust... Then a couple of times either in 2nd or 3rd it starts to sputter like, lurching forward i suppose. It doesnt happen all the time. And it seems like its shifting too high but idk about that. I went to AZ and got a speed sensor, they only had one, and i was going to replace the output first and drive and see what happens. Then if nothing happens switch them and try again. OR is this speed sensor not going to fix my problem?
2004 wj limited 4.7
IRO 3in lift with skyjacker hydro
265/75/16 TreadWright Claws
Gunrunner23 is offline
post #2 of 15 Old 07-06-2012, 05:21 PM
bradywgn71
bradywgn71's Avatar
It could be the Throttle Position Sensor. I replaced mine when I had shifting issues and it cured it. If it's bad, it could also cause lurching.
bradywgn71 is offline
post #3 of 15 Old 07-06-2012, 05:23 PM Thread Starter
Gunrunner23
naw i replaced that.. ALL THOUGH im not saying that it isnt bad too. but the only reason im not trying out the speed sensor right now is because im not getting a CEL...
2004 wj limited 4.7
post #4 of 15 Old 07-06-2012, 05:26 PM
bradywgn71
bradywgn71's Avatar
I didn't get a CEL for the throttle position sensor either. I had seen here on the forum that it had cured others shifting issues so, I gave it a try for $30. It just seems to be a part that wears out yet affects so many other things.
post #5 of 15 Old 07-06-2012, 05:33 PM Thread Starter
Gunrunner23
which did you replace input or output? or both? like i said the second one wont get here till tomorrow. They only had one. The guy was like are you sure u need two? Im like uhhhh yeah bro i need two... SHESH
2004 wj limited 4.7
post #6 of 15 Old 07-06-2012, 05:39 PM
bradywgn71
bradywgn71's Avatar
The throttle position sensor (TPS) is on the side of the throttle body. There is only one. It's not a speed sensor.
post #7 of 15 Old 07-06-2012, 05:40 PM Thread Starter
Gunrunner23
crap i see what you actually said. I meant i didnt have a CEL for the speed sensors which is why i think its not the speed sensors.... Sorry
2004 wj limited 4.7
post #8 of 15 Old 07-06-2012, 05:42 PM Thread Starter
Gunrunner23
Yeah i took the TB off twice and cleaned it REAL good and replaced the TPS, IAC for a crap idle issue that I AM STILL HAVING on top of this. Sorry for the confusion.
2004 wj limited 4.7
post #9 of 15 Old 07-06-2012, 05:48 PM
bradywgn71
bradywgn71's Avatar
No worries! I bought my TPS from O'Reilly's and it has worked well. If you bought your TPS from AZ, I have read on the forum that there has been occasional issues when using one from there. Our WJs seem to be sensitive to the quality of the sensor and many on the forum won't use anything but genuine Mopar parts.
post #10 of 15 Old 07-06-2012, 05:48 PM
narnwv
narnwv's Avatar
Did you get the TPS at Autozone too? If so, take it back and get a Mopar one.
~Aaron
narnwv is offline
post #11 of 15 Old 07-06-2012, 05:50 PM Thread Starter
Gunrunner23
No AAP BWD. Ive never had problems with Warner before so i went with it. BTW the IAC is mopar.
2004 wj limited 4.7
post #12 of 15 Old 07-06-2012, 07:01 PM Thread Starter
Gunrunner23
So back to the speed sensor. If one was going bad or is bad would it throw a CEL?
2004 wj limited 4.7
post #13 of 15 Old 07-06-2012, 07:02 PM
narnwv
narnwv's Avatar
not necessarily. These WJs have all kinds of sensor issues without throwing codes.
~Aaron
narnwv is offline
post #14 of 15 Old 07-06-2012, 07:08 PM Thread Starter
Gunrunner23
Well I guess ill throw them in. 42 bucks isn't bad for two new sensors I suppose.
2004 wj limited 4.7
post #15 of 15 Old 07-06-2012, 07:09 PM Thread Starter
Gunrunner23
Thanks narnwv ur a lot if help!!!
2004 wj limited 4.7
Transmission Input Shaft Speed Sensor, Output Shaft Speed Sensor CaRJoE0220 WJ Grand Cherokee Forum 12 10-29-2014 05:47 PM
Output speed sensor shanks26 WJ Grand Cherokee Forum 11 04-16-2012 03:56 PM
Speed Sensor Macfadden WJ Grand Cherokee Forum 6 05-19-2011 06:32 PM
Speed Sensor p0720 jeepfixit WJ Grand Cherokee Forum 1 06-11-2004 11:01 AM
