Spark Plug Removal/Installation - JeepForum.com
post #1 of 16 Old 01-02-2012, 06:14 PM Thread Starter
RaptorPDX
2003 WJ
Wj Spark Plug Removal/Installation
I will start by saying I am the most novice car guy. The extent of my experience is changing oil and a basic 2" suspension lift. With that said, I do love to tinker. I have a 2003 Jeep Grand Cherokee (WJ). 4.0L I6.
This project started because I kept getting a P0306 fault code, which was a misfire in cylinder #6. After talking to friends and scanning jeepforum I first put some Chevron fuel injector cleaner into my tank and second decided that changing out my spark plugs couldn't hurt and would hopefully be the culprit. Thirdly, I couldn't find any thread on jeepforum that included step by step (with pictures) instructions on how to do the change-out. wjjeeps.com has really good instructions here http://wjjeeps.com/service/sparkplugs.htm
But what I have benefitted much from in the past is someone's documented instructions (it also helps to know that someone else had the same difficulties with something I did...makes me feel less of a dummy).
So here it is:
1. You need the right supplies. Go to the autostore and pick up a small tube of spark plug boot grease and anti-seize thread lubricant. Also you will need a 3/8" drive 6" socket wrench extension and a 5/8" spark plug socket wrench attachment. I didn't realize how vital an actual plug socket wrench is until I realized that inside it is a rubber ring that holds onto the plug as you pull it out. This was HUGE! Finally, I got 6 Champion Platinum Power Spark Plugs (#3034/RC12PEC5).
2. Unattached the negative (black) battery terminal. This will take a 13mm wrench. I like to tuck the terminal around the side of the battery to ensure it doesn't flip up and inadvertently touch the battery and kill me.
3. In order to access the spark plugs I had to remove the coil rail assembly. On the link above to wjjeeps.com there is a great illustration of it. Below is the pic of the actual thing. Before you do anything there are 3 small cords (or hoses) that lay across the rail assembly that you should unclip, followed by 2 larger hoses that run parallel to the assembly that can unclip as well. Move these aside carefully so you don't pull anything apart. It was vital that these get moved so you have room to maneuver. FYI... things get real tricky on the bolt and plug on the innermost side of the assembly (nearest console).
4. Take your 13mm socket wrench and remove the 4 coil mounting bolts. Again the furthest bolt from the front will be the hardest and you will swear the most whenever working in this area of the engine. There is another plastic bracket at the rear here that you can simply pull it up and off the bolts that it is set on; move this towards the left as far as you can.
5. Next you will need to remove the coil connector from the coil assembly rail. This took me at least 20 minutes of complete frustration to disconnect. There is a red slide clip on the back of it that will need to be slid to the opposite side (right). This will take some maneuvering of the assembly as much as possible to access the connector enough to unclip it. Once the red slide tab is slid over (you'll know you did it when it "clicks"). Next push in the second release lock, located below the slide tab. Push in as hard as you can and the connector should slide off. Be patient, it took me forever but I finally got it. This was by far the hardest part of the project.
6. Once the assembly is disconnected pull it out of the car and the spark plugs will be revealed. Take your socket wrench with the 6" extension and plug wrench attachment and begin to remove each of the old spark plugs. Turn hard. As I removed each plug, I marked each one with the number cylinder they came from so I could further check out the #6 misfire my system was reporting. It turns out the #6 (closest to the console) had very little left on the spark part (sorry I don't know the actual term) but compared to the others it looked quite worn.
7. I then wiped a small amount of the anti-seize lubricant on each of the new plugs' threads with my finger. Next I then screwed the new ones into the plug holes. I don't have a torque-wrench so once the plug was tight I turned it an additional 1/4 turn. After all plugs were installed I took the coil rail assembly and lubricated each plug boot with the boot grease. I used some q-tips for this and wiped each boot down thoroughly.
8. Next I reconnected the coil assembly back to the coil connector and pushed the slide tab back to the left (opposite to lock) and fit each boot onto each of the spark plugs and set it back over each bolt hole. Using the 13mm socket wrench I bolted the coil rail assembly back and re-clipped the hoses and cords back to their appropriate clip and cleaned up.
The jeep started great and the check engine light was off, so that's a good sign. I hope these pics and instructions help someone out there. It felt good to take care of my jeep today and hopefully this will help my mpgs and life of the truck.
RaptorPDX is offline
post #2 of 16 Old 01-03-2012, 06:47 AM
corymonster
This is a good detailed post. I'm sure someone will get some good use out of it.
corymonster is offline
post #3 of 16 Old 01-03-2012, 01:13 PM
n8man1068
2003 WJ
yeah, someone like me, who has had a new set of plugs sitting on the kitchen counter for months. Just haven't gotten around to doing it yet.
03 WJ IRO 3" lift, DT8000 shocks, Addco swaybars, JKS quick disconnects, IRO xfer skid, IRO adc control arms, Rola roof rack, Uniden 510xl+firestick 2, K&N drop in filter, Cragar soft 8's, Hankook Dynapro ATM/RF10tires
n8man1068 is offline
post #4 of 16 Old 01-03-2012, 02:14 PM
specia1k
Nice write-up. Skimmed it, so if you stated the anti-seize thread lube and boot grease were "optional" my appologies. They are...
2004 Jeep Grand Cherokee Limited 2x4 4.0L
2002 Jeep Grand Cherokee Sport 2x4 4.0L
1998 Jeep Grand Cherokee Laredo 2x4 4.0L
"Three daughters, three Jeeps"
specia1k is offline
post #5 of 16 Old 04-11-2012, 02:06 PM
ppiya123
2006 WK
i read somewhere that the platinum spark plugs dont work very well with the 4.0L. anyone have any experience with that?
ppiya123 is offline
post #6 of 16 Old 05-18-2013, 01:31 PM
vandep32
this may be a dumb question but will a 5/8 deep socket work instead of a 5/8 spark plug socket?
vandep32 is offline
post #7 of 16 Old 05-18-2013, 02:23 PM
rcwj04
yes you can use a regular socket, the only difference between those and spark plug sockets is that spark plug ones have rubber to grip and protect the porcelain on the spark plug
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #8 of 16 Old 05-18-2013, 07:15 PM
vandep32
very useful thread. i was able to accomplish this in 30 minutes! Thank you!
vandep32 is offline
post #9 of 16 Old 05-19-2013, 06:00 PM
madmax
madmax's Avatar
That's true. Stick with old school Champion spark plugs.
2000 WJ 4.0L, drop-in K&N filter, Addco rear antisway bar, Bridgestone Revos, Overhead DVD monitor w/ wireless headsets.
2007 BMW 335i, Montego Blue with Lemon seats, premium & sport package.
2004 TJ Sport 4.0L - SOLD :(
madmax is offline
post #10 of 16 Old 05-19-2013, 08:47 PM
vandep32
well i just swapped to champion platinum power spark plugs yesterday and i have noticed a sudden decrease in mpg. I also filled up my tank of gas yesterday too. I followed this thread to a T so i dont think i did anything wrong. i was averaging 14-15 city now i am around 10 mpgs. Maybe i will be swapping spark plugs again. anyone have some advice on new ones to get?
vandep32 is offline
post #11 of 16 Old 05-19-2013, 09:20 PM
madmax
madmax's Avatar
Many of you probably don't realize that the 4.0L engine was originally designed in late 1960's. So, it's best to go with old school Champion (copper) spark plugs.
madmax is offline
post #12 of 16 Old 05-19-2013, 09:26 PM
charleswilson90
2003 WJ
I agree with the Champion plugs. I have tried about three different brands and my 4.0 definitely only likes the standard champion copper plugs. That is great considering they are almost $50 cheaper than the crazy platinum 4 tri spark ninja plugs.
charleswilson90 is offline
post #13 of 16 Old 05-20-2013, 12:15 AM
pinky2252s
Just get champion coppers. The ones that are like $1.29 each.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #14 of 16 Old 05-20-2013, 07:21 AM
bama1965
Nice write-up with good pics.
PS: The 4.0 loves absolutely loves Autolite Double Platinum plugs (APP985).
http://www.rockauto.com/catalog/x,ca...,parttype,7212
2001 WJ Laredo / 4.0 / Select Trac / 2.5" JGCP BB Lift / 1.5" RC Spacers / General Grabber AT2 255/70 16
bama1965 is offline
post #15 of 16 Old 08-24-2013, 08:05 PM
FedUp007
Thanks for the write up... I used this with much success! And you were right... disconnecting the coil pack and removing it were the hardest parts of the whole process!
Failure is the chance to begin again, with increased intelligence... 100
FedUp007 is offline
spark plug cover Amadauss WJ Grand Cherokee Forum 8 11-05-2011 09:12 AM
spark plug gap .035 to .040 does it eat more gas ?? Derek_88 WJ Grand Cherokee Forum 3 08-20-2011 02:03 PM
Broken spark plug jpaytoncfd WJ Grand Cherokee Forum 3 07-14-2011 09:51 AM
Spark Plug Change - How Often? 00JGC00 WJ Grand Cherokee Forum 33 11-16-2010 08:23 AM
Spark Plug Replacement in the 4.7 Astorm WJ Grand Cherokee Forum 7 04-30-2004 02:23 AM
